Score!!!!!!!!!!!!!!!
cchambers
Sioux Falls
SD
Score two dana 44 and a nonrunning 360 for 100.00
i got to leave the body with him and he got the tourch out!
Cut the u bolts and had to cut the straps on the drive shafts.
Don't know the gears in the axles but hay i can rebuild both axles for less than one thats done.
Any advice on how to shorten the length so they will fit on my 1981 nt?
Also hipro parts for the 360? I feal like a little kid that just got away with something.:d
WOW :bow: :drool:
There's a great thread by Grantshire on here that has ALL KINDS of detail about shortening 44s.
What side is the pumpkin on for the front?
BullTear is the one place I know that does AMC performance stuff.
Good score!
If they're widetracks, like out of a Cherokee Chief, you can take 4" out of the long side, it will then match the perch width of your stock axle. then get a narrow rear and you're set.
If they're narrow like out of a standard Cherokee or Wagoneer, I'd probably just get an outboarding kit and call it good.
Passinger side drop need to get the tape mesure out yet to check the length.
Im going to finish what i have now. Then next year axles and 360 cid.
But i will need to find a t176 to hold up to the v8 right?
I would find a T176 for that motor. Or, find a T18. That's what I have behind my 360.
