the jeep had been sitting outside for 2-3 years in Pennsylvania but it was the bed liner and good drainage that saved it. i scraped off very old window tint (NOT FUN) and started on the bed liner with the help of my daughter.
front brakes and rotors needed replacement and there was a sheared bolt in the hub. the rears were fine.
pass side was no problem new rotor and pads, and also drilled a drain hole for the upper shock mount.
put the hub and rotor on bench drilled out the bolt, best this ever went. put in the E-Z out
and holy crap it came out PERFECT
cleaned all threads with thread chaser, put on the rotor, pads.
threw out all the crap bolts and kept the grade 8 ones and added my own.
MURPHY and i were putting the hub on and spinning on the bolts with a 3/8 hand socket and a grade 8 bolt snaps off in the hub the whole enchilada (not the 1 i replaced)
now im thinking this hub is cursed. next day i got lucky again sent Murf home.
next was put in a yj power brake setup. now it stops 10 times better, no cj should be without this mod
these links were helpful
http://www.jeepforum.com/forum/f8/power-steering-power-brake-upgrade-1018298/
http://www.desertcj7.com/yj_brake_booster_upgrade.htm
NOTE: if you have a line flaring tool like i do all you need is the weatherhead fittings, not the adapters. that way you gain more room for the carb linkage.
