During the time I was doing the welding I had an epihpany with the roll bar.
It is hard to see/visualize, but basically I wanted the roll bar as close to the front of the bed as I could, but it wasn't working out the way the Scrambler bars are bent.
HOWEVER
If you flip it around...
It tucks right up to the corner if you turn it around.
I also think from my "visualization" method, that when the red one flips around (after removing the legs), I will reattach the legs and it will then end up mounting to the top of the wheel wells.
Visually from the side it will have the same angle and such, but the bars will be tucked up closer to the cab, which is what I am trying to do.
What I didn't want to do is an LJ/JK style where the bars are bent towards the back... also with allin the 20 or so inches, I didn't want super log back bars on a different angle.
We will see how it turns out, it is only metal, I can alway put it back to the way it was...
I will have to figure out something with the front feet mounting plates though as it doesn't line up perfect, but that is for another day.
