Spankrjs 1985 Spring Special CJ-7
Took some of the top parts off the carburetor so I could remove and clean the idle tubes.
Reference picture for me:
Took this top plate off to take a look, everything moving freely, no debris in here, looks OK.
Take these parts off:
Then you can get to the idle tubes.
Two screws and the entire venturi cluster comes out.
NOTE: I also removed and reinstalled the little check ball to blast out a few more ports with carburetor cleaner. Be careful with this, very easy to drop it down into the intake/engine!!
Using torch tip cleaning kit to check/clean the idle tubes for obstructions.
Blast carburetor cleaner through the tiny port inside the big circle. One for each tube. This is how fuel gets inside the brass tubes.
Blasted out all the little ports in this part with carburetor cleaner, too.
Make sure to reinstall the little check ball before reinstalling the removed parts. Be careful!!
Then reassembly.
  • Like
Reactions: SKT
Good news/bad news: no real gunk or varnish observed, no blocked idle tubes or ports that jumped out at me.
Restart took a bit of effort, all the fuel and carburetor cleaner flooded the engine when I was screwing around. Finally started up, idled like crap for a bit, finally cleared up. Quick test drive, maybe marginal improvement.
Little bit more screwing around, unplugged the vacuum advance, engine did not immediately drop RPM which I thought was odd? After a few seconds RPM would drop. Vacuum advance hose definitely pulling. Plugged that hose back up, unplugged the 4"/10" vacuum switch and drove around. Not a good idea, you have to really baby the throttle to keep the engine from falling flat on its face. So, just assuming that thingy is doing what it is supposed to. Plugged it back in, another quick drive, a bit better. Drove some more, sometimes almost no issues, then they would come back. Very intermittent.
I improved the situation or it improved itself, at least it is not violently bucking/surging during light throttle anymore, but the stumble is still there.
Sprayed brake parts cleaner around carburetor and intake, no vacuum leaks were found. Maybe a vacuum hose leak somewhere?
Things Jeep does perfect:
Starts right up
Shuts right off (no run on or dieseling)
Idles perfect
Choke working properly
Sol-Vac working perfectly
High speed operation perfectly
Heavy and light acceleration perfect
Things Jeep does not do well:
Steady light throttle to maintain constant speed, slight surge or buck. Better but still present. From 5 -40ish miles per hour.
The same buck/surge is also felt while decelerating, either with foot 100% off pedal or normal slow lifting of foot off pedal to slow down with vehicle in gear.
Did not notice a "light show" from spark plug wires with hood up/engine running outside in the dark.
So, maybe a carburetor blockage that is slowly working it's way out?
Maybe a slight vacuum leak leaning out mixture?
Maybe idle mixture set a hair too lean (was not a problem 6 years ago).
Maybe timing off (was not a problem 6 years ago)
Maybe vacuum/mechanical advance not working properly in the distributor, maybe sticking? Did have this issue 6 years ago.
More work/diagnosis needed, that's it for now.
Piddled with this one some Saturday morning.
Decided to investigate the distributor/timing.
Distributor installed, twisting the rotor, it would spring back but the weights were not swinging back consistently each time, at least the one I was looking at through the square hole in the pick up base plate. That might be normal, not sure.
So, decided to investigate. Pulled the center gear thing off (don't lose the roll pin), then the pick up coil. First thing I noticed, one of my springs is loose, providing no "spring" back at all.
Loose spring:
Tight spring:
I kept both the original springs I removed from the distributor with these two aftermarket light springs.:
Comparison, left to right:
Too loose original spring
Spring I had installed, too loose
OEM spring I reinstalled
Unfortunately, no real data on what springs are used in what OEM application. Only way to verify is to map the Advance curves, which I did before, probably need to do again. I imagine some tension at rest is better then none. With none, getting some mechanical advance at idle, besides the initial advance you set.
Spring installed, note dry oil wick/sponge in top of distributor shaft.
A little drop of oil added. I imagine this dried out due to the Jeep sitting up a long time. A little dab will do you.
Put a little plastic safe oil (rc car crossover product) to the plastic bushings on the Advance weights.
Took apart the Advance plate to add a little lube here, too.
A little dab on the three yellow dots and on the center raised metal portion.
None of these parts were sticking on the bench, but a little lube won't hurt.
Reinstalled everything, don't lose the little PIA roll pin!
It is easier to slide gear down the shaft, then install the roll pin.
Quick test drive, a bit better, but still have the surge when transitioning from idle to low speeds. Better, but still annoyingly there. The whole engine/Jeep is not bucking anymore, bit still not right.
So, hard to know if anything I have done has improved anything, or maybe I still have a carburetor blockage that is working itself out.
Checked the timing, some information. Just remember, this Jeep is still using the MCU to control timing, so not like a regular carburetor/timing set up.
Everything hooked up, engine running at idle speed of around 600 RPM, only 8 degrees advance showing.
Unhooked vacuum advance and vacuum switch, total timing at idle of 600rpm is 6 degrees. So MCU only allowing 2 degrees of advance at idle?
So, looking at my underwood sticker, checked the timing at 1,600rpm, around 20 degrees total (this is with switch unplugged and no vacuum advance).
Should be 11 max, I was around 20 degrees.
Adjusted down, idle drops to 400 rpm.
Shut engine down, hooked up vacuum advance and vacuum switch, restart, base idle at 500rpm with 6 degrees advance showing.
I just added a bit more advance, so probably back where I started. Quick drive, a bit better. So, Shut Jeep down, came back took it on a 10 kile trip, it was crap. Not bucking, but terrible low speed operation. If you.are barely on gas it surges. If you give it more pedal it is fine. Drove it to my buddies house, it stayed parked about 8 hours. Drove it home, much better, but still present.
Very inconsistent. Wondering if I just have a carburetor blockage that is working it self out. I'll work on it some more next week when I get back from Hot Springs.
That's it for now.
Rev engine way up and at the same time have Jeepaddict slap his hand over the top of the carb. It works 100% of the time about 2% of the time.
Piddled some more with this one off and on this week at night after work.
Swapped out the ignition control module, just for the hell of it. This Jeep had been running a NAPA top of the line module. Swapped in a budget O'Reilly module I had been running in my green Scrambler over 10 years ago, before swapping that one to Mopar fuel injection. No change, problem still existed after swap.
A note on modules, including the above picture.
Almost any new module you buy today is made in China. Best bet is to find a NOS Ford Motorcraft module. Interesting note on the above modules: the expensive NAPA and the cheap O'Reilly module are the exact same part. Same case, wires, everything. Only difference is the sticker, and the warranty. IIRC, expensive NAPA module has a 3 year warranty, budget O'Reilly module is lifetime warranty. So, buyer beware.
Anyway, ignition control module seems to be OK.
I also checked the ignition coil, both hot and cold, it checked out fine.
About the only bone headed thing I did recently to this Jeep had to do with the "Deceleration Valve". This is an emissions part, usually only found on California emissions manual transmission models. This part goes between the upstream pulse air tube/manifold vacuum source/big vacuum port on back/bottom of carburetor. Something to do when you dump off gas pedal, manifold vacuum soars, does something. Anyway, it needs to be mounted in the correct orientation, metal end up. There is some type of spring loaded diaprahm in there, can give you a very hard to find vacuum leak. I mounted it upside down when I installed the new valve cover gasket, not a good idea.
The Deceleration Valve, mounted in the correct orientation:
Close up of the metal top of the valve:
Reinstalled correctly, no change.
So, at this point I was about to start blaming everything under the sun: EGR Valve, coolant sensor, vacuum switch, carburetor.
I noticed tonight that it is more of a miss, not a flat spot. It got worse tonight when I was messing with it, consistent miss no matter what. So, being a redneck, I start pulling spark plug wires off plugs with the engine running to see if I could find a dead cylinder.
I pulled #1 off, noticed a difference, put it back on.
Pulled both #2 and #3 off at the same time, no change, got worried, maybe head gasket issue.
Pulled #3 and #4 off, very minor change.
#5 minor change, #6 big change.
So, let's pull spark plugs. All plug wires are firing. And hard. Not as hard as HEI, but they pop pretty good!!
  • Like
Reactions: SKT
This is going to look BAD, and it is, BUT it is not oil, this is all carbon. All 6 are covered, #1 and #6 are the cleanest. They are located at the far ends of the intake manifold, so makes sense.
#2 and #3:
#5, not as bad:
#1:
All 6 are black, middle are the worse. Not oily or wet, all carbon.
These plugs did not have many miles on them when the Jeep was parked 6 years ago. I am hoping the combination of old gas, dumping gas/ spraying brake parts cleaner down the carburetor to get it to fire up, spraying two cans of carburetor cleaner down the carburetor, and all the gas tank additives caused this.
Handy dandy service manual the above spark plug picture came from, I absolutely love the cover art on this book!!!
So, six new spark plugs installed, driving/running about 95% perfect again. Drove it around for about 45 minutes tonight, all speeds, lots of stop and go, running great and gets better the more I drive it. Going to burn two tanks of fuel through the engine, pull out the spark plugs, and see what they look like. Hoping all this is carbon/crap fuel/additives, especially how all 6 plugs were fouled out. Not thinking oil burning, especially all six cylinders, and the plugs are dry. We will see.
Look forward to driving it, especially since it is running really well again!! Surprised it ran as well as it did before swapping out the spark plugs!!!
That's it for now.
Great weather today, drove around for about 6 hours. Some interstate, back roads, even some Mobile, Al, big city traffic.
Running great, still have about 3/8 of this tank of fuel still left.
Believe I am going to be installing some valve stem oil seals sooner rather than later. After sitting at long red lights, smell a slight whiff of burning oil for around the first 60 feet. No puff of smoke, but I can smell it. Just a little bit, but it is there.
Will definitely swap in some valve stem seals before putting a new set of spark plugs in, especially when 6 regular copper Autolites cost $25 😑
That's it for now.
No rest for the weary, let's pull the top of the engine apart, again!!
Starting point:
Marking vacuum lines with blue painters tape:
I love the reusable valve cover gasket, no mess to clean up. I washed the vave cover gasket with Dawn dish soap, it is drying. 12 valves, 12 valve stem seals.
Checked the oil this morning, 1 quart low. So, way too much oil consumption in less than 300 miles. Some of the loss was from the old valve cover gasket leaking, but I'm gonna say it burnt half a quart.
The original plugs at the top are worse, but the bottom set with less than 300 miles is getting bad, too.
Interesting note, some of the plugs are stained only half way around, other ones all the way around. Left plug is cylinder #1, Right plug cylinder #2.
The oil looking stuff on the spark plug threads is anti-sieze.
Late in the day, toward the end of the long drive, I could feel the slight miss coming back. Looking at the plugs, I can see why, they are almost fouled out again.
Just some reference pictures for me.
1983 timing cover marks, note the v-belt pulley:
This 1985's timing cover marks, note the serpentine harmonic balancer pulley:
#1 Top Dead Center, distributor:
Approaching TDC at the balancer, note the line on the harmonic balancer.
TDC at the distributor is showing sooner due to the mechanical advance I have dialed in.
All six spark plugs out, transmission in neutral, easy enough to spin engine over with a 3/8 ratchet on the crank pulley bolt.
Mechanical fuel pump, turning engine over by hand, better have a cup handy to catch the fuel that will come out the fuel supply line!!
We installed these seals in Andy's Jeep last year, using an air compressor to keep the valves from dropping. This time, I wanted to try the old "rope inside the cylinder trick" to keep the valves from dropping. Basically, have the cylinder's piston you are working on a bit below TDC, feed a bunch of rope down the spark plug hole, gently turn the crank to compress the rope against the valves, keeping them from dropping into the cylinder when you remove the valve spring/retainer.
I used this rope, wanted soft rope, this is soft. Another size bigger would have probably worked better, but this will work.
Cut about 4' off the bundle, fed it down the spark pluh hole, pushed it in with a flat screw driver. Nice and easy, watch the threads. I stuffed the cylinder full, slight crank turn with the 3/8 ratchet, about this much hanging out, valves compressed.
This works, kind of a PIA compared to compressed air, but much quieter. Given the choice, I would pick an air compressor, but this will work.
One cylinder at a time, I started at #1, keep everything organized and clean.
Rockers and rocker bridge removed:
Organized:
Valve spring compressor I use:
In use:
  • Like
Reactions: SKT
The PIA part, removing the keepers. You must compress the spring to get to these little bundles of joy.
Two keepers per valve. Be careful not to drop these down inside the engine!!! Once exposed and loose, I use a magnet to remove each retainer, one at a time.
Valve stem seal, hard black plastic, brittle. This is the exhaust valve, cylinder #1.
Yep, in pieces.
Intake valve, cylinder #1, more of the same:
Lubricant I am going to use:
What the new seals, and install tool, look like:
I was going to use these, not 100% sure they are correct, so I ordered a new Felpro seal set to verify.
So, cylinder #1 will look like this for a bit:
Quick note: If you are using compressed air to keep valves up and run into a problem like this, fear not. As long as the piston is close to TDC the valves will not drop all the way out of the valve guides into the cylinder. Or, peace of mind, put a wooded clothes pin/plastic zip tie around the valve stem to keep it up.
That's it for now.
New Felpro valve stem seals:
Instructions:
The seal kit does not supply a sleave to go over the valve spring retainer ridges to protect the seal during installation. Might not be necessary with this style seal?
I wrapped one layer of scotch tape around the valve retainer ridges, just for shits and giggles:
That, lots of lube, they go on with moderate force using the included plastic install tool:
No reason to bottom the seals all the way down. Once the valves go up and down the seals will move to correct location.
Removing the tape was actually a huge PIA, but necessary.
Valve spring/top cap on the compressor tool over the valve stem:
Not gonna lie, this requires more patience then skill, kind of fiddly, installing the retainers. After you get the first valve completed you will figure it out. Don't try to smash them in. Hard to explain, but kind of make sure you place the retainer in straight up and down. Don't angle them when installing them. Once you get one or two valves completed you will get the hang of it.
The wonderful little retainers.
I will gently smack the top of each valve/spring/retainer assembly with a plastic mallet just to make sure the little retainers locked into place.
Balance of parts for this pair of valves installed.
Two down, ten to go, that's it for now!!
Decided to follow the firing order, so hit #5 cylinder next.
Note the rags stuffed in the head openings to prevent me from dropping the valve retainers down inside the motor.
The rope down the cylinder trick to keep the valves up works, but it probably adds 5 minutes per cylinder. But, you also have silence compared to an air compressor cycling on and off, so a trade-off.
Compress the valve spring at least this far down for retainer removal/reinstallation.
A lot of repetition, but finally finished.
And a bunch of dried up crunchy valve stem seals, 12 to be exact.
Quick reference, new valve seal ID:
And an old seal ID:
Might not seem like much, but in actual hands on handling, huge difference. All of the old seals would easily slip on and off the valve stems, no resistance at all. The new seals had to pushed down with a lot of force. The new seals fit tight, but you can still manually force them up and down. This style seal is designed to fit tight to the valve stem and ride up and down with the valve. The old seals were probably all just resting at the bottom.
Pretty good amount of work, hopefully this fixes my oil burning issue 🙏
And complete.
The damn power steering face plate to water pump threaded boss bolts kicked my ass. This serpentine set up is a PIA compared to the V-belt set up, but it will stay since this is a California Jeep.
Will fire it up tomorrow and see what happens. I have some new oil leaks at the back of the pan, so will probably drop the oil pan and install a new rear main seal and oil pan gasket next. And while I'm in there might as well pull the timing chain cover off and change the front seal and inspect the timing chain. That should be all of the engine oil seals. Then, the Dana 300 is leaking, and I've never pulled the front axle apart.........
That's it for now!!
