Back to the fuel system
I am using an "in tank" fuel pump on this Scrambler. But, I also wanted to mount and plumb an external fuel pump, in case the in tank pump died in the middle of nowhere. So, my fuel system is kind of complicated.
Picture of the primary components, besides the previously installed in tank pump:
My "map":
This MPI fuel rail only has the supply line, what is commonly referred to as a "return less system". But, there has to be a return line for the excess fuel/pressure to go back to the tank through. In this system, I am using a late model Grand Cherokee fuel filter,which has a fuel pressure regulator inside. This filter mounts back near the tank, with a short return line.
I am using the original fuel sending unit supply line to feed the external fuel pump. I am not using the original fuel return port on the OEM sending unit. I am using the OEM fuel gauge sending unit to work the OEM fuel gauge.
I am using the TanksInc in tank pump fuel supply, fuel return, and "t'eed" this extra fuel vent line to the OEM vent line.
Picture of the Grand Cherokee fuel filter/pressure regulator:
The Grand Cherokee filter comes with fittings that are made to work with the OEM nylon fuel line stuff. I wanted to use high pressure rubber fuel line, so I placed these fittings on the filter in place of the OEM fittings, worked perfect:
Fittings installed on the fuel filter, used conduit clamps as mounting brackets for the external fuel pump and the fuel filter:
Fuel lines installed and roughly routed:
I used GM style electrical connectors on the chassis fuel pump harness, and both fuel pumps. So, I can easily unplug one fuel pump, plug in the other. I also mad a "dummy plug" out of a connector to keep the unused fuel pumps plug clean:
I installed a replacement fuel supply line, the long metal line that runs down the passenger side frame rail from the tank to the engine bay. It's OD was a hair bigger then the OEM line, so I used a socket and hammer to slightly open up the OEM retaining clips, worked perfect:
