SpeedHut install thread
It sounds like a bad bulb. Try some that are known good ones in all places on that side.
Just checking to see how you like the Speedhut clock after a few years of use? I'm thinking of getting one for my Jeep.
The light problem might be a faulty ground. I have SpeedHut too and I think they are very ground sensitive.
I love my Speedhut gauges and clock. Just reset the time on my clock the other day after charging a dead battery. I put a hole in the dash for the adjuster button and it was definitely the right way to go. When I went west to the National in SD it was easy to adjust the clock for the time zone changes as I went and you end up disconnecting the battery enough that it's worth the extra hole IMO.
Looking forward to you review after install. I may go this route and watching and learning, thanks for posting.
Update on Speedhut Guages
Wow! Hard to believe its been more than 3 years since since I started this.
This has to be one of the easiest reviews to write ever. I absolutely love the Speedhut gauges. I haven't had any issues in 3 years.
The clock works great; and is easy to set. Only downside on this item, and I knew it going in, was that the clock doesn't get the same LED driven illumination as the rest of the gauges.
Tachometer works really well. Very responsive; no issues.
Oil pressure gauge has been great. I am sure the new OEM quality two wire sensor is more accurate and longer lasting than the AMC Jeep one wire sensor.
Not much to say about the voltage gauge. Works great. Easy to tell if the alternator is charging (at 14V+) or not (12.3V).
Speedometer is easy to read and works great. Once in a blue moon if the Jeep hasn't been out of the garage for a month or so; the gps will forget its location and will take a block or so to find it and then start working (I didn't put provisions in for the backup going into the TC). Getting rid of the cable going to the TC was one of the best reasons to go to the Speedhut setup; one less mechanical, trouble prone, mechanical cable.
Fuel gauge works great at this point. It did take me a couple of months to get the "range" setting in the Speedhut setup correctly. I have 98% confidence of not running out of fuel with this gauge. Why 98%? Because I didn't replace the AMC float style sender (that may eventually fill with fuel). I am kinda kicking myself for this detail. I have already decided when I retrofit to fuel injection that the tank will get a more modern sender, either the Speedhut capacitance one (requires one more wire to the fuel tank) or I may do the GM LS in tank pump assembly.
Temp gauge works well. Accurate enough that I can tell almost exactly when the thermostat is going to open and level out. I wish it had actual temperature numbers (I know it would be less historically correct; I'd be fine if they made it read from the multifuction display in the middle) for tuning my fan controller. I also wish this had come with a 2 wire OEM type sensor.
The Painless / Speedhut swap had to be the biggest improvement in reliability of any of the changes or fixes I have made. Before I did the swap, it would reliably leave me troubleshooting with a multimeter or test light on the side of the road every couple months. Now it has been a couple years since that happened; and it was with wiring that wasn't part of the swap (the wire going from the ignitiion relay fell off the terminal to the HEI).
Great project!! Highly recommended!!
The speed hut gauges are custom built so I think you could get numerical indicators on the temperature gauge. I also loose the Gps signal sometimes after coming out of the garage but it's only happened three or four times. I also have a Scan Gauge 2 as backup and they both register the same reading. Scan Gauge 2 is really cool to have on a '96 or newer truck. OBD2 required.
I read this yesterday and had to wait to post until I checked mine. Why don't you have the clock on the same dimmer? I have everything on the dimmer and mounted it right below the clock.
That's my one other tip on these gauges is to go ahead and mount the dimmer somewhere you can easily reach while driving. The lighting (I did the full backlight option) is very bright and when it's fully dark out I actually crank the brightness down a good bit. With the combo I did, when it's just getting dark, it's nice to crank them fully bright, so I actually change the dimmer a lot.
I think this is different with the "black face" and indiglo gauges. My black face clock, the numbers are red and light up and dim (similar to my other gauges) but the hands on my others are LED blue and light and dim; where the clock hands don't light up.......might be a reason to go indiglo style...
Ahh, that's it. My clock hands don't glow either, the face lights with the others similar to how the numbers work on yours but with the backlighting you can still tell the time. I do think it would be great if the hands should light up like the gauges somehow but I'm guessing the two hands is what screws that up.
I've also got Speed Hut gauges. Some r hooked up others haven't been installed yet. Anyway for those that have replaced the speedometer what did u do 2 cap off where the old cable attaches to the transfer case? I do not want 2 leave the old cable attached just 2 cover the hole.
Interested to see this as well, I just zip tied the speedo end behind the dash with it hooked up at the tease.
There you go. Also wondered if you could just chop the cable near the fitting on the tcase, pull out the cable stub and then cap the cut sheath with an appropriate cap and reinstall.
I just cut the cable a couple inches long and capped it. Don't remember what I used to cap it.... I removed the cable inner cable so nothing is spinning.....
How about a engine freeze plug with some sealer on it?
I did what BigWalton did. Just zip tied behind dash (on cj7). Water can't get in and cable spinning isn't hurting anything.
