Suggestions on modifications to a bare frame for family cruiser?
sevensandeights
sevensandeights
Mckean
PA
I plan to pick-up a frame for my Scrambler in 2 weeks from ACE. I am looking for input as to what modifications you would suggest before I paint it and start to transfer parts from my existing Scrambler with a rotted frame. This will be a family cruiser with no hardcore wheeling in its near future (maybe that will change in 8 years or so when my oldest turns 16). I don't plan on more than a 2.5" suspension/1" body lift and 33" tires max. I rebuilt this Jeep about 8years ago and it already has a 4.0L swap, 32" tires, 2.5" suspension lift and 1" Daystar body mount lift. The suspension lift was transferred from my CJ7 and is a little tired and alot rusty.
So, any suggestions on:
1.) shackle reversal
2.) power brake booster
3.) wide track axle swap (I have a set laying in the barn)
4.) power steering bracket brace and new steering shaft
5.) F250 shock tower upgrade
6.) YJ spring conversion (SUA)
7.) etc . . .
4.) power steering pump brace/bracket
7.) etc . . .
1. Personal preference. You'll get a great ride out of it, but I think they are slightly less capable off-road, and you have to deal with driveshaft slip issues. For what you're doing it's probably worth it, but I wouldn't.
2. No modifications needed. You just need the bracket and booster. It's a worthy upgrade if you have/buy the parts.
3. No modifications needed. These will bolt in. I prefer the wide-track axles (as did Consumer Reports). Consider one-piece axle shafts for the AMC 20, and swapping to the 6-bolt front hub assembly.
4. No modifications needed. Again, the frame will accomodate the stock box and your engine will accomodate a stock pump. VERY worthy upgrade if you have manual steering.
5. This is a worth modification IF you don't have the later-model shock-towers. If you've already got the late-model towers, this is essentially a waste of time. The later shock towers bolt to the earlier frames and require no modifications.
6. This is a worthy modification. The front YJ springs are longer and wider, and therefore softer. It doesn't take much to move that front shackle-hanger forward (there are several write-ups about this), and if you're doing a shackle-reversal, you should definitely swap to YJ springs at the same time.
Thanks AK - I know some of those are not true "modifications" but now would be the time to do since the I have to swap everything onto the new frame.
Since my Scrambler is 1981, I am assuming I have the early style shock mounts but I don't know for sure.
Unless you are re-using power brake parts you already have; go with a duel diaphram unit like the Navaho from Off Again or Vanco's unit. They stop way better with these.
Vanco's kit was the one I remember reading about a few years ago. I want to say there was an interference issue with 4.0L manifold though - can anyone confirm or dispute this?
Yep, spot on....I guess I'm a stronger proponent of the shackle reversal though, I've fabbed them on every CJ I've owned. Road manners are noticably better and I haven't really noticed much of a disadvantage on the trail. Usually I'm modifying driveshafts at the same time anyway....I usually run a little longer slip joint.
I don't plan to change the driveshaft since I am not going with a bigger lift. Does this always need to be done or only if heaving wheeling/flexing is expected?
By "fabbing them" do you mean you welded on new shackle/spring hangers? Have you ever used YJ springs?
4.) power steering pump brace/bracket and new steering shaft
7.) etc . . .
My thoughts...
1) no, see #6
2) yes, dual diaphragm as mentioned, Vanco is actually a member on here, you could look him up and PM him (if he doesn't find this already)
3) yes, with one piece rear axles
4) do you mean the power steering box? definitely
5) yes if you're already looking at new shocks
6) Any nice supple spring will work well for you and YJ width is the way to go. I think a good selection of springs will negate the need for the shackle reversal.
7.) etc . . .
1, Absolutely. My 82 is the first CJ I've owned to have a shackle reversal. I should have done it to all the CJs I've owned in the past. On road is night and day compared with the stock setup. Off road, I have not seen anything negative...yet.
2, Dual diaphragm is the way to go.
3, Wide tracks if you got'em. As mentioned, 1 piece axles in the rear.
4, Steering box brace (and mount) if your wheeling. Shaft, Borgeson or Flaming River are two good names.
5, This frame has no shock towers, so the F250 ones are the way to go.
6, Absolutely, when combined with #1, your ride wil be like butter.
7, It's already plated and has a HD rear crossmember installed.
See you next weekend.
As far as the driveshaft....if you do a shackle reversal, when the spring compresses and the shackle is to the rear, the axle moves reward slightly more than normal. Probably not enough to worry about driveshaft changes if you are not changing the ride height. I usually move the front axle slightly (less than an inch) forward to compensate (not too far though...you have to maintain proper steering geometry/clearance for the pitman/drag link.)
Yes, I weld them on the front, w/the rear hanger, I insert/weld a tube in the frame w/bushings to hang the shackle from.
I have not run YJ springs...and I agree that they probably are a better spring.
Scott - pics of your front shackle hangers would be greatly appreciated!
I have read up on both the YJ spring conversion and the shackle reversal conversion. Most folks on this site seem to favor both. However, I have read alot about "nose dive" with hard braking after the shackle reversal. I understand why this happens but wonder how big of an issue it really is. Any comments?
Also, I have read that YJ springs are a little flatter than CJ springs. I like the height of my Scrambler now with 2" CJ springs and the Daystar body mounts (about 1" lift). What size YJ springs will I need to stay about the same height and clear 33's?
I'll take some pics and post them up soon.
Regarding the nose dive w/a shackle reversal; I have not really experienced any notable nose-dive, but the Jeeps I have done this mod to have run 2.5" & 4" lift CJ springs. I suppose you might experience more w/a softer spring. Some guys have angled there front shocks slightly to combat this.
On my CJ-8 I am running a D44 front end w/GM style brake calipers...so I have notably more stopping power over the stock calipers.
Scott - any chance you could post some pics of your SRS? I am starting to accumulate parts to work on the frame. I already have a set of M.O.R.E. fron spring hangers though so I don't know if I will be able to cheat the axle forward any.
Can a driveline shop just lengthen the splines on a stock driveshaft or is a completely new driveshaft necessary?
7&8s:
PM me your e-mail address and I'll shot some pics off to you. Unfortunately they are too large a file to attach here. (Some day I need to figure out how to reduce the file size...)
7.)etc.-------Replace the stock brake lines with stainless steel lines----perfect time to do it!:twocents:
This is the reply I got from M.O.R.E. -
Jeff,
We recommend cutting away (notching) your reinforcing plate just enough to allow the shackle plate to articulate and hopefully you won't have to cut all the way to the top of your reinforcing plate. Then you can still use our stock weld in tube and weld it to the frame. Please call us if you have any other questions.
Thanks again,
Scott
Any shackle suggestions?
I have the older style 4WD Hardware HD shackles on my CJ7 and CJ8 but the ones on my CJ8 would need repainted and don't have greaseable bolts.
