Sway Bar Disconnect, Am I missing some thing(s)?
MomoJeep
Seattle
WA
I got the disconnects for my swaybar, with 2.5" lift. But...
(1) even on level ground, the two sides never seem to line up. Is my swaybar twisted or messed up?
(2) It's a pain to pull out the pins, and put them back in, because it's never aligned in a "resting" position. Isn't there a better product or way to easily disconnect and re-connect?
Thanks!
Could you put some pics up? I have always been able to move mine into position pretty easily even though they aren't perfectly aligned...
I suppose I could take some pics. But nothing looks abnormal. Except that when trying to reconnect, on level ground, it's about 1/2"-3/4" off. For example, if I reconnect one side, that how far off the other side is.
Just have someone turn the steering wheel. That generally is enough to raise or lower the front end. If it's a long way off, just have your co-pilot hang out the door.
I had JKS disconnects on the Scrambler and fought getting the pins. After a while I decided that was enough and pulled them off and re-drilled the hole in the pin that went inside the other half. Just the inside pin and just a little, worked much better.
I had to use a hi-lift to lift up one side of my jeep to get the swaybar pin to slide in (JKS)
Not abnormal at all for the holes to be off at rest.
The other thing I found out is I would unhook on one trip and for get to hook back up. Get to the next trip and find I had not hooked back up. After doing this a few times I just pulled the sway bar off. Never really noticed any difference.
On a CJ5 I had did the opposite forget to disconnect and go to hook them back and find I didn't disconnect. After a few times of doing that I just quit disconnecting at all. I never really noticed that much difference either way.
If I forgot to reconnect my swaybars, I'll roll my stuff over. When I was on leafs, my Jeep drove like a Trophy truck with the swaybar disconnected. I'd guess that your springs are a bit too stiff which is acting like a swaybar-
My Scrambler is stiff. The cj5 was softer but the sway bar didn't seam to change much how it drove on or off road.
I used to cary an axe handle to leverage the disconnects back into place. I took the sway bar off when I went to wider axles.
I have JKS disconnects on my red Scrambler. The first side hooks up easy. The second side, I don't fight with it anymore. I put a bottle jack under the u-bolt skid plate and jack the lower pin upward till the holes line up. Way easier then prying :twocents:
My red Scrambler will wallow around pretty good on the street without the sway bar hooked up.
My Swaybar makes a difference. But it bugs me that it's not easier to connect/disconnect.
I forgot to unhook mine for a number of days off-roading. My radiator bracket broke causing the fan hit the shroud. I think it was because the extra twisting on the frame with the swaybar connected on very uneven terrain (Southern Utah).
