- Ducor
- Ca
I’ve been fighting with the same issue
That is not one of Jeeps / AMC better design areas. Any time a top is on, it is just difficult.
How about replacing the "swing latch" with a toggle clamp, something like this:I’ve come up with some ideas, the hard part is designing something that is “bolt-on” and doesn’t require messing with the exterior paint.
Hard to say. The old weatherstrip was pretty weathered and flat, so the tailgate lined up with light pressure but was loose. I’m realizing that the main culprit is the too-fat weatherstrip. That’s a common problem with most replacement weatherstrip. The second part is the latch system- the two spring washers allow too much slack, and the sheet metal “striker” is not tall enough or adjustable.I would be curious to know, did the taligate line up with the top of the bed from the factory.....
Totally not helping this topic, but daggum your Scrambler is nnnniiiiccceeeeeBringing this thread back from the dead. Has anyone figured out how to build a better mousetrap? I mounted my tailgate tonite and while it fit great, the latches are loose. I even went for the Kentrol replacements. And once I installed the weatherstrip, it stuck out 3/8” on the top corners! I made some UHMW spacers and that helped some, but there’s got to be a better solution. Any ideas?
Tailgate installed.
Closed with spacers-
View attachment 88302View attachment 88303
Spacer-
I guess there is a reason the factory changed to a swing gate on the TJ.
THAT is a bold statement!YJ first, but exactly right. Not sure if there's anything I hate more about the stock CJs than the tailgate latches. Even the wipers are better IMO.
Eric- I had thought of doing that on my Copper Scrambler. My mental gymnastics imagined a Poison Spyder swing down carrier with the tailgate attached. I gave up when I tried to design a power lift assist because that would be a hefty load. Would have been cool on Copper.
While I think doing something like you suggested would work great, I just don’t want to do that kind of a mod on this Scrambler. I want to keep the tailgate. The draw latch on your picture was an option I had considered, mounted on the rear supports, but I decided that would look a bit “off” on my build.
Keep the ideas coming! I enjoy seeing what you all come up with!
And I appreciate it!That’s why I initially said it wouldn’t be one for you. Just letting the ideas flow...
Glad you brought this idea to the table. It really has my wheels turning?That’s why I initially said it wouldn’t be one for you. Just letting the ideas flow...
