Also ran the harness from the fuse box to the rear. Mounted the tail lights, need to get the hole drill bit to mount the side lights. Also connected up the wiring to the fuel tank. I need to wire the tack, the fuel gauge and stereo speakers. At that point the wiring is done except to re-run and connect the wiring going to the radiator and front lights. Also going to have to decide on new flares or flares that I was going to use on the other cj8. If they look right, the fiberglass body may be a good choice to trim for the flare fit. More I look at the mock-up (put up against the other cj8) I'm not sure I would like to trim that much?
