The long road...Don't Laugh!
1981cj8
Riverton
UT
So I have posted a few things here and there, but no one knows what my project looks like. It's pretty bad right now and it will be a long time before this thing gets on the road. Its an 81 and it was cheap. Basically 700 for a title, axles, dash, and a few other miscellaneous parts. No hood, no grill, no engine, no trans, and no transfer case. From the outside the tub looks okay, but some interesting patchwork and a lot of bondo hides the mess underneath really well. I already have a frame for it and a tub. The frame needs work and I am currently looking for a shop in SLC, UT to straighten it out and then I will work on strengthening it more. It was in an accident on the passenger side. I posted a couple pictures of the tub on another thread. It has some fire damage. It has a lot of surface rust where the fire got it, but the metal under the rust is solid.
For now, it will be all about the work that can be done without any expense. A bad rental investment :banghead: is taking all the extra cash until the housing market turns around.
This is my 3rd jeep. The 1st was a 77cj5 that I parted out to pay for stuff on an 83cj5 that got sold to pay for some expenses on the rental. I always wanted a Scrambler and now I get to build it from the ground up.
attachment.php
Can't wait to see the progress. Sorry to hear about the rental. With craigslist and this forum you can do a lot on the cheap.
Just found someone selling a bulkhead that looks good for $25 and good hard doors for $50 each!
game on :thumbsup:
I just HAVE to say it....
awww....It doesn't look that bad....Man that feels good, it's been a long time since I got to say that...;)
:rotfl: :thumbsup:
The passenger side of the new frame I have sits up a couple inches high over the drivers side and there is a little bend in the center. No kinks or anything crumpled, so It should be easy to straighten it back out. I have talked to 2 shops in SLC about putting my replacement frame up on their racks to straighten it. One wanted 260 just to put it on their rack and then it would be an hourly charge after that depending on how long it took to get it straight. The other shop said 50 an hour. Both of them wanted springs and axles attached to the frame to do the work.
Its going to have to wait for a little while though. Had knee reconstructive surgery last week and can't get the springs/axles attached until I am a little more mobile. I also have to repair the rear spring hangers before I can attach the rear axle. One is smashed and the other was removed for some reason.
Did a little disassembly this last week before it gets too cold to work outside. While taking the body off the frame I found an interesting fix. aluminum riveted to the original body and then bondo and some sort of fiberglass mixture to cover up the seams. The rust underneath wasn't even that bad, so I don't know why the PO didn't just fix the existing metal. Also found a piece of aluminum that went from the front of the rear wheel wells past the firewall to the front fender and bondo'd to cover up the seam. There was a huge plate covering up the bed. Here are a couple pics of what things looked like under the plate. I will post a couple pics of the aluminum and bondo fix when I get another minute.
Here are a few more pics of the tub disassembly. I got the dash, windshield frame, rollbar, and anything I could save off the tub. Any metal that might be used to fix the other tub I have I am trying to keep. The whole floor was pretty much unusable.
wow, that's a bit of rust there, did you find that thing in Utah? I'd have thought an import from Michigan or something with that level of cancer
Please say you are swapping tubs and not fixing that one,
Title history shows this one coming out of New York. Before I even crawled under it the 1st time I looked at it, I knew it would need a new frame and tub. I am cutting up some of this old tub where the metal is still good to save for repairs on the new tub I picked up if/when it needs it. :rolleyes:
scored cheap parts
Found a deal here in SLC on front and rear wide track axles this week. $25 for the rear and $50 for the front. Also picked up a decent hood for $20 and front grill with headlights for $50. Everything has a little surface rust, but its a good starting place. Still working on the frame right now. I have everything removed from it so I can get it ready for POR-15 coating.
Man, I miss those good deals out of Utah. I remember Atlas in North Ogden used to have the coolest stuff before they got shut down...
Found another good deal yesterday. Picked up a nice windshield frame with wiper motor and wiper assembly for $25. The glass is cracked, but that won't be too expensive and all the hinge holes are clean with no broken bolts in them.
Progress is slow, mostly just watching for good deals on parts right now. I need to think more about where I want to strengthen the frame before coating with POR-15.
From the looks of it... a good bit o work but it really looks like a great saver. Kill that rust with some of that converter acid. Maybe hose some Naval Jelly to really kill the crud, brush and apply the POR. I bet you'll be pleased with the results. :thumbsup: Anxious to see some more results!!
More parts...
Couldn't pass this up. CJ-7 frame with 32" tires, wide track axles with superwinch hubs, 20 gallon tank, motor mounts and a few other things. $200 for it all. I am planning on keeping the tank and the axles and selling everything else including the pair of widetracks I already had. I should be able to get that $200 back and maybe even come out ahead. We will see.
Spring Hanger Question
The replacement frame I got had the two rear spring hangers removed for some reason. These are usually held on with two rivets and I think one weld. I am planning on just welding them on and not worrying about the rivets or even putting bolts through the rivet holes. Anybody think I should just bolt them as well? I don't know how I would hold the nut or the bolt with a wrench or something inside the frame while I tightened it down. Thoughts?
Weld the nuts to a rectangular plate and slip it inside the frame. The plate won't be able to rotate, so you won't need a wrench on it. Be sure to drill oversize holes in the plate before you weld the nuts.
Was able to disassemble the cj-7 frame and axles today. It's supposed to snow tomorrow and I wanted to get it done before the storm came in. The shackle bolts didn't cause any problems, but the spring hanger bolts required some heat and a sledge. I didn't notice this before, but the front axle has sway bar disconnects on it, :thumbsup: one more thing I don't have to buy. Later this week I hope to take John N's suggestion for bolting the spring hangers back on. Here are a couple pic's of the CJ-7 taken apart. The backyard patio was my workshop today since the wife took over the garage to paint a dresser and some picture frames.
I finally got to do John N's suggestion for bolting my spring hangers back to the frame. Here are a couple of pics. The little plates are about 1" wide and just a little longer than that. When I got the frame it didn't have rear spring hangers and the new spring hangers I picked up from a salvage yard still had part of a frame with the rivets attached so I used that for measurements. I am going to coat the plates and nut with some rust preventive paint and everything will be ready to bolt to the frame. Then I will weld the hanger to the frame. Sad that it took me over 3 months to find a little time to do this.
