regular guy
- Cameron
- NC
Day 1
Began disassembly. Here's the before picture
Started with removing the screws for the transmission access plate and the shifter boots. Took off the shifter knobs. From there, dropped the rear drive shaft.
Next, I tried to pull the transmission shifter, but because I replaced the isolator clip and rubber isolator, It was stuck on like crazy and I couldn't get it off. There's a learning point in there somewhere.
Next step was to jack up the transfer case just a hair in order to get the jack stand under the engine. Removed transmission mount bolts and skid plate bolts. Encountered second issue, First major one. My skid plate is further back than factory because of the 4.3L Vortec. On the left frame rail, the very back bolt was free spinning in the frame. After monkeying with it for about a half hour, got a cut off wheel and cut the damn thing off.
Here's what my skid plate carried around.
I think I might have dropped 20lbs off the gross vehicle weight
Pulled the Dana 300 with relatively little issues. Pulled the speedo cable and unplugged the electronic sender. Unhooked the vent line and the 4WD indicator. Remember to pull the stick as it's a pain in the *** to have that thing sitting on your chest on the creeper and trying to monkey around with getting the stick out of the access hole.
This is going back in as a twin stick
The transfer case was definitely leaking from every gasket. and the rear output shaft. It looked like the front was good and the seal to the transmission was good.
Next was the transmission. Unhooked the vent line and pulled the four bolts from the bell housing.
The chevy bell housing has 5/8 bolts on the tranny side and 1/2 bolts on the engine side. My inspection cover for the bottom half of the fly wheel was toast. I removed the starter to take out the rest of it. The two bolts attaching the clutch linkage to the bell housing were both loose. Pretty sure PO couldn't get a wrench back there so he just hand tightened them. I played the 5 degree of wrench turning for 15 minutes to get the top one out. Then the bell housing came out pretty easily. On to the clutch. 1/2 inch extension one hole to gain leverage and removed the clutch. Here's what a smoked clutch looks like. Hardly any plate left.
I am betting on a great test drive.
