Tips for yanking bushes
ScramFam
Registered User
Nowhere
OH
As soon as I pick up my new Jeep I hope to put it to work pullin shrubs out of the front of my house -- I told you I was going to get this one dirty. Any tips? Will a tow strap do the job? How do I keep from tearing up my lawn?
It depends on how big the bushes are. To save wear and tear on the strap, would use a short chain to go around the bush two or three times then latch back to itslef, preferable with a slip hook. You could also use your strap, just make sure to wrap it at least twice as much of the base of the bush at practical. Put a couple of feet in the line and give it a decent but not hard snap. May want to try from more than one direction if its troublesome.
Of course, if you had a winch, just use it without a problem in the world. If you don't, than you need to go ahead and buy one. :D
It depends on the size of the bushes. I used my winch to pull out chainlink fence posts before. Dig out around the base and yank it. We tried this method on an old Crape Mertyl (sp?) in my parent's yard where they were putting in a pool and the dig and yank method didn't work because it was so well rooted. So I ran over it. :D
Put something over the strap. When/if it comes out, it may come flying....ask me how I know this :eek: :D .
I did this with my 2000 Wrangler, 6cyl, 5spd, without tearing up the yard.
Not bad advice from Kdaddy. I wouldn't snap the line, though, unless the bushes are REALLY big. Like John says, it will come flying.
I used a poly tow rope. My bush was medium size, about 6 ft tall and 6 ft around. Dig around it first, especially on the side away from where you are pulling. Pulled slowly and stopped a couple of times to cut away at roots that were exposed.
Might not be as exciting as snapping that baby out of the ground, but I didn't break anything either...or get hit with anything flying. :cool:
4 angry squirrels in reverse
Did this..
this is just a 4cyl, these were some pretty good sized ones.
just used a tow strap and wrapped around the trunk of it closest to the ground.. a few tugs..
Thanks, once again, great advice!!!! The bushes are low lying and fairly established. I have the project on my to do list for next Saturday. I'll let you know how it goes.
tips for bushes
I used a old 5 on 5 wheel to change the direction of my pull slightlly.
use a small chain to go round and round the bush trunk then attach a strap to the chain. drap the stap over the circumferance of the wheel so you are pulling up and then over across the wheel when attached to the jeep. I mouse my hooks with duck tape so nothing comes loose and use a slow pull and weight your stap cause more than once I have had a stap and bush hit the jeep when using to much stupid pedal. I also suggest stronglly that you dig around the bush and cut some roots. Remeber the root system of the plkant is often much larger than the actual plant itself above ground.
