- Silver City
- NM
Recently I wanted to get some YJ soft uppers for my Half Doors with the round upper corner. Well that was easy enough to find but they do not have the little round-ish part at the bottom back to fit the top... Then I pulled in next to a TJ at work the other day and there it was... They have the little round-ish part at the bottom back, but they DON'T fit... Or do they?
After some research I found that with a little effort you can make them fit... So I bought a pair of TJ uppers with busted zippers for $25 bucks and made them fit
Here is the pair of uppers I got...
First you have to cut the old skins off... I'll tell you that is strong stuff.
After the skin is completely off...
What you have to do is make the front down pin stick out a little further. Sorry didn't take a pic of this one before I welded the piece in to make it longer, but here it is already on...
Then you have to move the rear pin in a bit... Here is after I cut a bit out and after I welded it back together...
With it on the door inside and out... The only pin that you do not cut and re-weld is the middle one. Basically you want to make the front and rear pins stick out the same as the middle one...
