TJ Door Uppers, YJ Half Doors, CJ Half Hard Top
1BADCJ8
Silver Member
Silver City
NM
Recently I wanted to get some YJ soft uppers for my Half Doors with the round upper corner. Well that was easy enough to find but they do not have the little round-ish part at the bottom back to fit the top... Then I pulled in next to a TJ at work the other day and there it was... They have the little round-ish part at the bottom back, but they DON'T fit... Or do they?
After some research I found that with a little effort you can make them fit... So I bought a pair of TJ uppers with busted zippers for $25 bucks and made them fit :thumbsup:.
Here is the pair of uppers I got...
First you have to cut the old skins off... I'll tell you that is strong stuff.
After the skin is completely off...
What you have to do is make the front down pin stick out a little further. Sorry didn't take a pic of this one before I welded the piece in to make it longer, but here it is already on...
Then you have to move the rear pin in a bit... Here is after I cut a bit out and after I welded it back together...
With it on the door inside and out... The only pin that you do not cut and re-weld is the middle one. Basically you want to make the front and rear pins stick out the same as the middle one...
Next you have to put the frame into the new Skin... This is a pain in the buttox to say the least. One thing you want to do is unzip the window to get in on. I tried the hard way and it was a drag... then thought to un zip the window and got it on, its still quite tight... Here its starting and with it on...
Next you put it on the door... You can see that it fit pretty good. However its not perfect and I will need to adjust the top and windshield frame a bit to get it closer but with no adjustment at all it looks very good...
And one from the inside...
Now of course I have to do the same to the other side... All told I'd say start to finish was about 3 hours...
This being my first step by step write up its prolly not done perfect but I hope this is help to someone else...
Why couldn't you just start with tj half doors?
I don't remember the difference between them
I believe you can modify the striker post on the CJ tub to TJ style, but then you have an issue if you ever want to switch back to CJ full doors.
And then there's the cost... TJ lower half doors sell for a lot more than the older YJ version.
