Trail Scrambler Build/Rebuild-Chiefwaho
CHIEFWAHO said:
Seams like I haven't got alot done lately.
Ah, now I see... Matt was way off, you don't have a machine that makes more hours in the day, ALL time in Kansas is shifted so a minute everywhere else is actually a week in Kansas... that's the only way to explain this comment!
I've had a slow coolant leak for THREE WEEKS, you've built the better part of an insane trail rig in that time... :banghead:
You need a little perspective adjustment my friend! :D :rotfl:
Had a business trip to St Louis and look what followed us home.
You're kidding right?? What are you going to do with THIS one?
When's the postal getting built in all this madness??? That's the one I'm waiting for! :D
Weekend progress!
Tub set back on.
47b8dd37b3127cceb6088b9bf2dd00000026101AaMmTRm4cMY
Had do a little trimming on the tub floor to allow room for the Atlas II.
47b8dd37b3127cceb608886eb2b100000026101AaMmTRm4cMY
47b8dd37b3127cceb6088542f20300000026101AaMmTRm4cMY
47b8dd37b3127cceb60888feb22100000026101AaMmTRm4cMY
Grill/radiator back on to check for clearance issues.
47b8dd37b3127cceb6089b18736600000026101AaMmTRm4cMY
47b8dd37b3127cceb6089dc773ba00000026101AaMmTRm4cMY
47b8dd37b3127cceb608923a33d800000026101AaMmTRm4cMY
Ended up with about 1" clearance between hood and Vortec cover (top engine).
47b8dd37b3127cceb6089326735c00000026101AaMmTRm4cMY
Also started fitting the body armor.
47b8dd37b3127cceb6089914f25b00000026101AaMmTRm4cMY
47b8dd37b3127cceb608962bb2fb00000026101AaMmTRm4cMY
47b8dd37b3127cceb60891daf29100000026101AaMmTRm4cMY
Got the passenger side wheel well cut out.
47b8dd37b3127cceb608942f33ce00000026101AaMmTRm4cMY
47b8dd37b3127cceb6089686336600000026101AaMmTRm4cMY
And the passenger side armor fit up.
47b8dd37b3127cceb608ab63f23500000026101AaMmTRm4cMY
Trying to figure out where to cut wheel well openings.
47b8dd37b3127cceb608aa3db2f300000026101AaMmTRm4cMY
Looked in the Scrambler and thought maybe I should hit up DeWalt for a sponsorship!
47b8dd37b3127cceb608aaf0330e00000026101AaMmTRm4cMY
And that is not the complete DeWalt arsenal of tools.
What!!!
I figured it would be running this weekend at rate you guys have been going on it.....:rolleyes: .......:D
Body Armour Good!
You can't go wrong with adding that stuff! It more than pays for itself!
So is 1" going to work for that clearance issue? What about engine flex?
Looks awesome! Can't wait to be with you when you wheel it! :)
Don't forget clearance for the steering shaft also. I take it that you are going to be using the stock exhaust manifolds?
Looking at that Atlas clearance on the tub, the position of the fan relative to the radiator and the motor mounts, is there any reason why you can't drop the engine down another inch or so?
I don't know what the motor mounts look like, but they seem to be up above the framerails pretty good and you have enough fan on the radiator to drop it down a little...
I had the same question about clearance with that Atlas torquing around and the engine/hood. Of course I know nothing of V8 swaps and what not, just looked/seemed close to me.
CHIEFWAHO said:
Jason,
I was just re-reading your thread from start-to-finish (drooling along the way), and wanted to ask what the additional plate is behind the 2nd-rearmost crossmember. Is it just for additional stiffness?
Craig
Maybe I missed it, but what brand of rear body armor is that? That's exactly what I'm looking for for mine.
1x1_Speed_Craig said:
Jason,
Craig
No real reason, just more beef.
Got them thru 4x4Land, Topeak, KS
(785-862-8008 ask for Mike)
Looking Good
Looking better and better all the time. I jus wish i had the patience that you guys have to do this type of build. Great Job.
They are wearing thin lately. Sometimes it nice to be in the middle of nowhere but it really does suck when doing a build like this that most everything is custom. Local parts stores know nothing beyond their computer screen if it doesn’t come up they have no imagination or sense enough to help beyond that. I wonder sometimes if they could even change their own oil.
Most times it's easier to make your own parts because it takes too much time to get it otherwise. Besides, it'll at least fit and probably work better than the store-purchased part.
I'm guessing that Mike at 4x4 Land could tell you, Sean. :D
Keep it up....in a couple months I'll run over that diesel turd of yours:D
bbaxj said:
Thanks! Mind if I ask how much they cost?
You really need to call Mike and talk with mine were custom with no wheel well cutout. I paid cash and don't even remember what I paid.
More minor progress.
Transmission/T-case support.
47b8dd11b3127cceb6a34a5410ba00000026101AaMmTRm4cMY
Changed oil pan from a truck to a camaro.
(loose 1 qt oil from 6.5 ro 5.5)
Pickup
47b8dd11b3127cceb6a34be7d1a100000026101AaMmTRm4cMY
Modified windage tray
47b8dd11b3127cceb6a34bd250a400000026101AaMmTRm4cMY
Big difference!
47b8dd11b3127cceb6a34953502400000026101AaMmTRm4cMY
47b8dd11b3127cceb6a34ebb916700000026101AaMmTRm4cMY
New dipstick and tube.
47b8dd11b3127cceb6a34ea0104c00000026101AaMmTRm4cMY
Shot from underneath.
47b8dd11b3127cceb6a34efa101600000026101AaMmTRm4cMY
Told ya all I would get rid of that RED wire loom.
Looks alot better IMO!
47b8dd11b3127cceb6a34ed0103c00000026101AaMmTRm4cMY
Mocking up track bar also going to add a truss.
47b8dd11b3127cceb6a34c42919f00000026101AaMmTRm4cMY
Crudely patched a few tub body mounts.
I keep telling myself it is a `WHEELER' doesn't have to be pretty,
cause I am going knock the snot of it anyway.
47b8dd11b3127cceb6a34c4c919100000025101AaMmTRm4cMY
Fabbed up a couple capture nut holders
I have an old military duece/half hood I use for material.
Good stuff alot thicker than standard sheet metal.
47b8dd11b3127cceb6a36daed1fb00000026101AaMmTRm4cMY
47b8dd11b3127cceb6a36dacd1f900000026101AaMmTRm4cMY
