Still need to add some oh ****! bars here and there, maybe a CB mount up above. Still need to get my down bars to the frame and add tabs for the 5 point harness's.
It cranked and fired today, but I can't keep it running. More research?
Also having some major issues with the Painless (only in name) wiring harness. Every circuit in the fuse box is hot regardless of key position. Wiper fuse pulled shuts off blower motor. Pulled every fuse and wipers still work. Voltage gauge stays on all the time. I am thinking painless has some major QC issues. And they do not include a wiring schematic. They are getting called first thing Monday morning.
MOTOR NOW RUNS!!!!
I was not maintaining 12V while cranking,
found a wire that did and presto it stays running.
As for the painless harness I am not impressed at all. They had a hot wire on the side of the wiper motor fuse and it was back feeding and making the entire fuse block hot. Nice quality control!
I enjoyed many trips in front of or behind Lee when he owned that rig, and I hope to be able to go on many with you (although I don't know if I'm going to be able to follow that beast!.....maybe if I ever get my big build finished! LOL.)
Jason, Nice work. What ratio did you go with on your Atlas? I just ordered a 3.8:1. I'll also have a TH400 w/513gears. I kind of stewed over what ratio to go with. Kim
Guys I will answer ?'s in time.
Been too busy building (still taking pics as I go).
It finally made it out of the shop for a drive Friday afternoon and it went wheeling Sunday for about 6 hours. Things seemed to work pretty well. I sure like the power of the 5.3L.
"As for the painless harness I am not impressed at all. They had a hot wire on the side of the wiper motor fuse and it was back feeding and making the entire fuse block hot. Nice quality control!"
amen! I used one of their harnesses on a simple 4 to 6 swap on my son's first scrambler, not again, doing my own on my cj 5 was far easier
Have not updated this for a long while.
I've wheeled an abused this rig for a many years since original build.
This is the best she has looked since that time.
I'm so ready for the National Scramble in South Dakota.
