trailer length?
cjrusty
belleville
il
well i am getting sick of trying to borrow a trailer to go out and play. so i am looking at trailers, and was wanting to go as small as possible. what is too small? i was thinking about a 16' trailer. other than room will there be a difference betwwen 16 and 18'ers as far as ride quality or weight dist.
16' will work fine. Given a choice, I'd go 18' for the extra room on the deck for a box or other stuff. My trailer is actually shorter than 16', but it was built for me when I was hauling a CJ-5. It wasn't easy to fit the Scrambler on there and get the weight distribution right.
I have not had a problem using my 16' Skidloader to trailer my Scrambler. I mounted a tool box and skidloader spare tire on the v-nose just ahead of the deck. The trailer is primarily used to move my skidloader, so therfore the d-rings are located for proper weight distribution for this machine. Hauling jeeps still works well, but I need to chain and bind it from locations other than the d-rings. I don't believe you will need an 18' trailer for better weight distribution and Scramblers fit perfect on a 16' trailer. The only benefit I see with an 18' trailer is having the extra 2' of deck for storage. I mostly work on tite sites, so the more compact the better for me. I will try to post a pic later.
I have a 16' trailer also. Extra space would help but not necessary. I load all the extra stuff in the back of my pickup.
Don
14' can work
Since that Picture I started backing onto the trailer. as JAC Inc stated getting weight dist. was important.
If you look carefully at the back, I had built a bin to store fuel cans etc. in the pic you can just see some yellow as I was carrying diesel jugs at the time
I would go 18. You will not be disapointed and the cost is about the same. Why are you thinking you want to go with the smallest? 18 will give you plenty of room to tweek you balance point. The better it is balance the better it will ride and the gas mileage will improve.
My thoughts
I run a 16' trailer with a 76" deck width for my scrambler. I'ts great fits on there fine, tows great behind a 99 tahoe. I have about 2 feet in front where i plan on mounting a box for spare tire and trailer accessories. Plus I do not have any over hang off the back of the trailer. What I did was take my scrambler to the dealership and he let me pull it on different trailers to see how i liked it. Todd
thanks for all the replies. i was wanting to go small as possible to save on weight/fuel. plus my tow rig is a 1500 w/ 4.8. i took an 18' with 2' dovetail to clayton and i liked the way it drove, but it was probably close to weight limit, if not over for my truck. i am not too worried about the extra room, i still have the back of my truck and scrambler.
18 and get brakes on both axles. The size and weight differance is minimal but thye payoff is tremendous. Never know what else you may wanna haul. You're jeep may even grow:D When you pull in the mountains you'll appreciate the dual brakes. I had a 16+2 dove and loved it but my jeep got to big.:D
Bigger is Better
I think 32 Feet works out just fine.:rolleyes:
I have had the best luck with 18 - 21. The longer the drag the smoother the ride and wxtra room is just another plus. 16 might be easier to use when you are in tight spaces but how regularly are you that tight on space when going to a wheeling spot... Not very often at all. You'll like the way a longer trailer pulls and so will your tow rig guaranteed.
The shorter the tow rig the worse ride too. If you get a trailer behind a 4 door long bed as opposed to a single cab short bed you notice the difference in pucker factor real quick!!!
I have an 18' and love it. Give just enough extra room for spare parts / camp gear, etc. as needed. Price was only another $50 (if I remember right) and not that much extra weight.
Mine is 13 feet long by 7 feet wide,I made it short,because at the time,I was hanging around a guy that messed with a lot of Ford pickups,and every tow dolly and trailer that he borrowed,came back messed up,so I made it short so he wouldn't want to use it.It hauls CJ 5's and 7's,with no problem,a 8 you just have to make sure it's as far forward on the trailer as possable,I've hauled full size Jeeps on it,it tows great.
