trailers
donaghy
CJ-8.COM owner
FORUM OWNER
Lexington
SC
I'm in the market for a car trailer to haul my eight around. I'm finally feeling guilty enough about always borrowing my friends trailer. So, called about a few and found one alongside the road that I am calling about.
But, thought I would approach the thread in there if any of you have any wisdom to share or points of reference you could add?
16' vs 18' vs 20' deck?
steel deck vs metal diamondplate deck?
And of course.. its a given for trailer brakes.
Was just wondering if an 8 rides better on 18 ft trailer vs a 16 just because of how it would be situated on the axles etc.
I found a 1 year old, 16 ft, dovetail, all steel deck, 7000lb trailer, w/ one axle with brakes. 15 tires. Guy says he used it once and paid about $2500 for it a year ago.
Needs one tire and a pigtail for the trailer brake wire..
It does barely look like it was used at all. he's asking $1500.
I really would like a gooseneck hitch, but storing it here at the house is just not feasible with the added room it needs for the hitch.
What is everyone using for trailering theirs?
Trailer
Here is my nickles worth---the 16 will be "OK"- if the guy is willing to,i'd see about loading your rig on it and pull it down the road,I really perfer something in the 18 to 24 foot range simple because sometimes you need to move the "load" around to make it pull right,I have a tool box on the front of my trailer that locks and i carry two spares for the trailer,jack,extra water,fuel,and tools not to mention some extra jeep parts,You will quickly find out that you will need to add brakes to the other axle,when you do i'll put you on a place that has fair prices on trailer parts,I'm going to convert mine to a goose neck in the very near future,which is always an option for you at a later date,I'm also going to add another 3 foot to the front of my trailer when i do it,As far as the floor wood is cheap,but rots,steel is heavy but won't rot out,but can be extremly slippery when it's wet and muddy,diamond plate helps with the slippery part but also adds weight,if it don't already have it you will need to add the brak-a-way breaking system to it to make it legal in all states,anything loaded that weighs over 3500lbs is suppose to have them,It's real simple to add and cheap also,-make sure and replace the tires with "trailer only" tires,it will pull better and the tires will last longer,if it has been sitting the last two years plan on four new tires,get them in the load range "D" for the weight of the Scrambler,no fun having blown out tires 200 miles from the nearest town(remember Colo last year) Dove tails make it easier to load a Jeep on them,but they also drag on every hump in the road or parking lot,so i'd recomend adding some sliders or rollers under the back of the dove tail-JC:p
i am using a 16ft open deck diamond plate dove tail trailer with one brake. Like jc i am also carring a tool box, with spare driveshafts and axle shafts front and back along with a host of other things in there and 2 spares for the trailer. My 8 tows fine on the trailer when i using my motor home to pull it (32' with v10 20000+lbs) But when i pull with my dodge (v8 extra-cab 1500) i definnitly wish i had an extra 2 foot of trailer and the second set on of brakes.
Also the dove tail drags a lot but not a big deal when going foward it is backing up that it really can cause a problem- when it digs in. But with the dove tail i don't need ramps to load and un-load the jeep.
..you can get trailers down here for less than 1500..you guys on the east coast should make a road trip down here and pick up an entire load of trailers and sell the extras to pay for the trip..
Over here you can get a new 16' car hauler with brakes on one axle for $995. If you use a 3/4+ ton truck one brake is enough.
'Course the last time I was in College Station, TX, I didn't notice too many real hills, let alone actual mountains. ;)
I've had my trailer 23 yrs., so I can't get into prices. Mine is 16', full decked with steel diamond plate, with the dove tail, but not so severe it drags. It's a standard pull, not gooseneck. I wish it were 2' longer to distribute weight better, but it does the job. I have brakes on both axles and a gear box on the front. The box on the front is large for spare parts, tarps, water and/or fuel cans, chairs, camping gear. I carry 1 spare and have new (last year) heavy duty tires, the type usually used on an equipment low-boy trailer.
I appreciate this thread because i too am looking into a trailer. I wonder if some of us could do a group or multiple buy and save some bucks? Anyway, thanks for the info!
P.S. There is a fellow on this board, Rob, who may make a trailer for me, perhaps someone else might be interested too?
16 VS ?
Ok we decided a 16 will work,but most of them have said they wish they had another 2 foot to move it and adjust the load,so that means at least an 18 foot trailer is ideal,I use to build trailers years ago for a living before i signed my life away to the company store:mad: Just some advice,i have a 20ft and wish i had another 2ft,so here we have a decision to make,an 18ft is ideal,but if we decide to convert to a gooseneck later you need to add lenght to the front of the trailer,the axles are located futher to the back on a gooseneck than on a bumper pull,so as i see it there are advantages and disadvantages,bumper pulls are easier to store and if you don't travel alot they are the way to go,if you pull it a lot and travel cross country then you can't beat a gooseneck,they pull better and track better, but take up space in the bed of the truck,so it boils down to what you want,i'm converting to goose neck since i pull cross country so much,with a bumper pull you will get some sway on the hiway,can be very bad if not loaded corretly,with a gooseneck it tracks behind the truck no matter where it's located on the trailer,so it depends on what you want to spend and how much you haul-JC:p
Here is my .02
I have a 16' Utility trailer w/14" sides. It is rated at 7000lbs gross and 5900lbs carrying capacity. It has brakes on one axle and has a Bulldog hitch. I bought this trailer 3 yrs ago for $1250 which included a spare tire. I initially bought the trailer for my construction business, but lately I use it to pull my CJ8. My CJ8 weighs 4040lbs. The trailer performs flawlessly and can be used for many more things than just hauling a Jeep. It has paid for itself many times over. The first time I put my Scrambler on it was the day I brought it home from Missouri 770 miles. 3 weeks ago I used it to pull my CJ8 to Red River, NM and back 1600 miles.
I think loading the trailer and maintaing it are the 2 most important factors when towing. You could have a $5000 trailer and if you load it improperly you will be in for trouble.
Later,
Tom
I AGREE WITH TOM
You can spend $10,000 or a $1,000 but if don't load it right and have the brakes to stop it,the ending is still the same and none of them are good!:eek: JC:rolleyes:
