Now what would someone in risk management have to say about this??...
Lets stir the "pot" some...
I don't know where you can find an un-galvanized metal trash can, but I suppose it's possible. If it's galvanized, I would definitely not recommend any such attempt. Fumes from welding galvanized metal will ruin your lungs. I know galvanizing will "cook off" at much lower temperatures, such as woodstove chimney flue temps, and probably at barbecue temps. Burning (glowing) charcoal is probably hotter than any woodstove chimney.
While it may not contaminate your food, to the extent that it will poison you (I believe your body requires a certain amount of zinc), it may damage your lungs, during the cooking process. I would have to recommend that you RUN, don't walk, away from this idea.z
