You should post this in the new members section and you'll get loads of input on its level. Kim Dawson is a Jeep whisperer and can probably tell you for certain.
So I will continue with this thread. My firewall tag is pretty rusted and needed to be removed because the front clip was being replaced. I can see the code on the front/back side and will eventually try a chemical or baking soda process to try to clean it up. Anyhow this is the tag information. Clarification as to what model/trim and paint code/color would be appreciated.
J149952 88
17 2D 3EB
1JCM88E1GTO27897
So you either had a SR (Renegade) or a base model.
If you have aluminum spoke steering wheel and rocker guards, it's likely a Renegade/ SR. If you don't have rocker guards and have a black plastic spoked steering wheel it's probably a base. No way to be sure either way the way they did options back then.
Thank you. Looks like an SR package. Rocker guards and steering wheel is as you describe. Also had the step up. It had the diamond plate pattern vs grip tape...not much left of them unfortunately.
