walkerhoundvm's rebuild thread
walkerhoundvm
Just trying to stay upright
Cave Creek
Engine has been mocked up. Exhaust manifolds sent out for ceramic coating. Spent some time this week on the harness to get it fitted correctly. Axle work being done this week, along with swapping in the RE suspension. Got a set of 33s mounted to the chrome wagons.
Next up, body work to get the W-O replitub shored up.
walkerhoundvm
Cave Creek
Some photos of the worst offenders in the replitub:
There's also a spot in the firewall where they bent the opening for the throttle cable. One of the fenders has a good bend in it, too. Pretty whack, but didn't get a picture of those. The internal measurements are just a tad off - the bulkhead doesn't fit in perfectly like it did in the OEM tub, but should with some work.
All in all, it's OK considering what I was working with. Provided it mounts up well (which it should, I had to replace the tub to frame mounts after all), it should be an acceptable working replacement.
walkerhoundvm
Cave Creek
Working on a 20g tank swap. Prepped and painted a skid, now waiting on a tank from a forum member :) IMG_20181123_161849.jpg
walkerhoundvm
Cave Creek
Wow. That chassis looks great!
Considering what it looked like at the start, I couldn't agree more. While the tub was pretty much shot from stem to stern, the frame held up remarkably well. Rust turned out to be pretty superficial.
certifiablejeep
Definitley Certifiable
Bedford
NH
It is really moving along... looking great.
The replitubs are what they are... they are new, no rust, etc. but the fit/finish is stuff you just have to work through unfortunately.
You can spend hours and hours replacing metal.
Can't wait to see where it ends up.
walkerhoundvm
Cave Creek
Spent the holidays getting a bunch of parts down to bare metal to speed up the bodywork/paint stage. Everything but the replitub and fenders.
Took quite a bit of work. There was OEM paint and primer under a PO layer of paint under a few layers of rattle can paint and primer. Probably 30hrs of sanding, grinding, and wire wheeling.
Also spent some time prepping and painting a few interior pieces that won't be body color (original copper brown metallic) to get those out of the way.
Hoping to be finished by this upcoming show: https://www.good-guys.com/sn but I'll be happy if we're done before the National Scramble :)
walkerhoundvm
Cave Creek
Looks great! Around here, bare steel parts would get a ‘natural’ copper brown metallic color almost instantly.
In the few years I've been here, I think I've been taking that for granted. There's maybe a touch of flash on the hood, but that's it. I haven't done the roll bar yet, but that's because I have no choice but to leave it outside, and this time of year we get rain about once a week.
walkerhoundvm
Cave Creek
Body work is finally coming along, worth the wait I think. The lines are a remarkable improvement over what we started with. Heading in Monday and Tuesday for drilling and mocking up parts, should be painted by Friday but we'll see!
AJ2393
Scrambled in the Head
Westport
MA
Just curious, no spot welds lines on the replitub? Or were they filled? That's on way I check for damage and previous bodywork when I look at buying a Jeep.
walkerhoundvm
Cave Creek
They're there! I think the color and lighting has made them difficult to see, but they're there :) Maybe not all in the usual places. Some of the lines inside the cab are so bad it'd require quite a bit of work to get them straight, so while unpopular the bed and the underbody are getting textured liner. I know, I know, but it's a replacement tub so no need to go overboard.
AJ2393
Westport
MA
Seems like a good idea on a new tub with no rust.
walkerhoundvm
Cave Creek
Just noticed no holes for the wheel arch spats or the chrome sill covers so if you are fitting them now is the time to do it!
The arch spats are on my list (had to look up "spats" :) ), but the chrome sill covers I'm lost on - rocker guards? If so, those are all on my list too :) I'm putting rivnuts in for the:
Dash panel
Half soft top windshield bracket and snaps
Soft door wind guards
Tonneau cover snaps (I found some with machine screws) and braces
Mud flaps
Bulkhead (all sorts for the top and tonneau and attaching to body)
Just about every footman loop
Mud guards attached to the underbody behind the rear wheel wells
Probably others I'm forgetting too!
