What did you do with your Scrambler today? August 2013 version
bigwalton
Alaskan Postal nutjob
FORUM MANAGER
Dexter
This thread is intended for a quick update or picture of something cool/fun/new/important that you did with or to your Scrambler today.
These should be very small updates and any details or long explanations/stories should be posted in a separate thread in the proper location in the most relevant forum. Ideally, you can make a separate thread and post a link to it on here with your quick update. This is in order to keep separate threads on topics that other people on the forum or in the future would want to see or search for and to keep great stuff from getting too buried in a general thread.
I closed the original huge thread in an attempt to make these roughly monthly to keep them more manageable and to add this opening post to each one so that we can keep the important nuggets in threads in the proper location on the forum.
Link to the original thread if you have a few hours to kill :D
https://www.cj-8.com/forum/showthread.php?36143-What-did-you-do-with-your-Scrambler-today
Alright gents... I've been fighting with emissions crap for a while. My 81 has been a Ca jeep it's whole life but just recently moved registration to TX. Still live in CA and because I'm on Base I have to comply with emissions in Ca for base stickers... A complet load of crap if you ask me (and just about anyone else) but it is what it is. I just discovered that my smog pump wasn't connected properly but cannot find good support or information on it (here or elsewhere). Now I've got a buddy dealing with the same. I finally just pulled the air pump out because it was causing bad popping and backfire issues when I decelerate. Any help would be appreciated. I started a new "emissions" thread to hopefully help others out too. Here's the link. https://www.cj-8.com/forum/showthread.php?t=39622
Ol'Red, you are my hero!
This is a *perfect* example of how this thread can be used to help everyone on the forum! Well done! :cheers: :thumbsup: :woot: :bow: :bacon:
Hooked the flux capacitor back up. I'm going to try to get it up to 88 later today and see if it still works.
So if you hook it up and it works will you let us know in a thread from a couple years ago after you travel back in time? So I guess the update would have already happened.
I was hoping for that exact reply. I'll post the results in the original "What did you do" thread. :) Then I'll start a new thread about the install. Oh...and I'll have a gigantic climate controlled warehouse full of Scramblers.
Smartass :rotfl:
I took both my postal and my Aqualu/TDK Scrambler out to Knik and set them on fire today because I miss the old thread. (But I agree with bigwalton that tech needs to stay out of this thread and leave it for chit-chat stuff.)
Put some new chrome rims on, courtesy of Dennis (ddavis). Thanks Dennis!!
The Laredo-ization is nearly complete! (rubs hands menacingly)
Just a thought...if you put a California Howell TBI set-up on it, you can legally take the pump and related stuff off (I believe). It comes with a sticker that cover the legalities. It might be just as cheap as restoring the smog pump system......
^^Ditto^^. That's why Howell kits cost so much: they're the only legal alternative to resourcing antiquated smog parts in many states.
You can get rid of the air pump, but must keep the original intake and exhaust, as well as thermal vacuum switch for EGR and charcoal canister purging. Air cleaners may be aftermarket...at least in northern Colorado.
Yeah, I've looked at the Howell kits but I'm already running aftermarket intake and exhaust. Got the charcoal canister and its hooked up properly. No EGR or thermal vacuum switch though. Researching Texas requirements now.
Got the new radiator installed. My 9 year old helped out. Filled it up and started checking for leaks. Leak 1 needed the upper rad hose clamp tightened at the pump. Leak 2 is unsure. Checked the clamp but it was ok. Leak is at front of engine, hoping it is just water pump, may have lifetime warranty on it. Was a steady trickle. Got a bucket under it to catch the green stuff. Any ideas guys?
