What did you do with your Scrambler today? March 2015 Verson
Different. And a lot closer. It was within the state. It was already sandblasted and will really not need much work at all. I need to replace the rear cross member. And while the mounts for the body have wallowed out holes, the frame came with new ones to weld it. This frame is in sooooo much better condition than the one I am using now. Pretty excited.
That is great! I'm excited for you! Definitely go with a ChiefWaho HD rear cross member!
Awesome!!!!
I finally got to cleaning up some coolant system plumbing that had been bothering me since last summer. Put a new radiator return hose that actually had a pre-formed 45 degree bend in it (the old one was somewhat collapsed to give it that bend). Also shortened both heater hoses. I left them way too long when I re-assembled figuring it would give me flexibility later. Turns out that extra length just allow it to move around when driving and contact my serpentine belt (could have ended really badly). New routing is much tighter and much better. I had forgotten how ridiculously oversized those original cast t-stat housings were (it must have been 3/4" OD).
Now - fill and drive!!! We need some spring weather!!!
Congrats on the frame!
Thanks. Now that it is light outside I will take a pic. I will post it up soon. But the detailed shots will end up in a build thread.
It came with new mounts and bushings.
New Seats!
So I really liked RandyZZZ's PT cruiser seat setup in his scrambler. It's taken a bit to find the set I wanted, but picked them up today! Now to figure out attaching to the seat brackets for now.
Good job on the frame, looks like it's time to get busy.:wave::popcorn: I want to be the first one:needpic: Crowd is already chanting.
I actually drove the Scrambler today for the first time since October. Felt great.
Karl
Drove it on a 3 hour round trip to return Chop Shop's trailer I borrowed. And then came home with a few odds and ends. Thanks Jim. Good seeing you again today. I hope that yours hearing comes back from the road trip on Sat (we were in a Suburban with glasspacks and a busted tailpipe for over 7 hours)
Nothing but we're off to the beach this weekend for Easter few days. Can't wait. I need to be rid of driving this pig pen everywhereImageUploadedByTapatalk1427880562.254074.jpg and get me somma thisImageUploadedByTapatalk1427880623.136326.jpg
Is the guy in the blue shirt saying, "Im not worthy, Im not worthy?"
Karl
I see you found a heated set! NICE!
I found that when I removed all the riser brackets on the bases, leaving only the sliders, I was able to adapt the sliders to the stock CJ bases using only some flat strap. IIRC the PT bases are a hair wider.
Hm there heated also??
I don't have the seat heaters. And in the pic above, the seats are actually in reversed position. The switch pods go to the outer edge.
Here's how they fit on the stock seat risers.
Current install, integrated into the cage.
How it looks today-
