What do you guys think?
Rubberhook
N. Cape May
NJ
About this new winch? They gave them away in the raffel at Oak Ridge! I really like the mounting plate by Toys by Troy! I'm up in the air between the new magnuim buy Warn or the T Max! Help me decide!! There both around the same price! About 550 range!The T Max looks stronger ,but Warn does have the name behind it!
The T Max
http://northridge4x4.com/proddetail.php?prod=TMAX-EW9500
The magnuim
http://www.gowarn.com/magnum-9k-self-recovery-winch.asp
Toys buy Troy winch mount
http://northridge4x4.com/proddetail.php?prod=TOYSWINCHPLATE
Here's a write up on the T Max
http://www.4x4xplor.com/T-MAX.html
For the oomph, the price on that T-max sure looks good. Don't know about quality though... find out if the magnets are glued or bolted in, we had a conversation about magnet failures at Oak Ridge.
The Warn should have bolted magnets, that's the better setup.
T-MAX
every thing i've read about the T-Max is good,kinda of a down under version of the Warn HS-JC;)
Well the t-max people approached me about selling their winches. After studying the numbers for quite a long time I decided not to. If you look deep into the numbers the line pull with 3 and four wraps still on the spool you'll notice the t-max fades quickly. Like 1400 lbs less and half the line speed if I remember correctly. I don,t really remember the actual numbers now cause i threw the lit in the trash but it was significantly less. After about an hour conversation with there rep I asked him if his winch is slower and less powerful tham a warn what is the advantage? His reply was "their cheap". I said" you said it". Thanks but I'll stick to my american made products. We have now sold a dozen of the magnums without any problems. By the way the name of the magnum will be changing real soon. Seems as though Warn kinda stepped on some toes with the" magnum" name and has decided to change it to avoid any conflicts. FYI Mike
TMAX-WARN
Thanks Mike.............Great info...........JC:D
