What's on your Work Bench?
About six random boxes of jeep nuts and bolts from 3 x cj10s, three Overlanders and a cj7. All gotta be gone through and sorted.
Yup, I printed out that civilian jeep link, I'll look up the other one when I get home ,
thank you
You're welcome. I need to redo my T176 in the shop, so you can do a build thread when you do yours!
Lots of pics in that IFSJ link. Doesn't look too terribly bad.
Thank god for my drawers of bolts
Kit bolts not long enough
Had to get my daughter to help me assemble this , had to bend the bolts to get the puller arms behind them
It won't budge, there's enough torque on that right now I'm afraid somethings going to break and catch me in the face
I tried Freon on the shaft
Then heat on the bearing
It broke free, and then I had to get another bite
That's the bottom of a 14 bolt I shaved
And I did this because I didn't think I could get it back together again
Finished product !!
Not on the bench but next up for install:
uu
Pretty. Looked it up and it was pricey, but then saw the reviews on the stamped steel pans and thought might not be so pricey after all.
Finished product !!
Not exactly instilling a lot of confidence in me with all the heating, cooling, and breaking.
When I rebuilt my t176, the bearings came out much easier, luck of the draw:shrug:
IIRC, removing the bearings is the hardest part of the entire rebuild:thumbsup:
The front bearing actually came out by hand
The back one scared me a little bit
Apparently this transmission sat full of water
I'm breaking this one down to get the front input shaft and the bottom cluster gear to rebuild another T176
For a change. Very little. Thursday night cleanup before the Michigan game. GO BLUE!
Yeah, you can't win if you have 3 picks and one a pick-6... there is more hope though now... saw some good things, need more running game, looking forward to having football back on either way.
