When is it no longer a Jeep?
Manhattan
Atlanta
GA
I started with a genuine (pronounced: gen-you-ine) bonafide Jeep CJ8 frame. The axles are rebuilt (Warn/Moser) Jeep axles. The grille is an NOS grille. It does have a Dana 300 t-case. After that... it gets pretty thin. The wiper motor and arms, steering column, tailgate brackets and (soon to be) hood hardware are CJ. The steering gear is J10... uhm... that's it. Oh, the VIN tags are from that frame and the long-gone body. Everything - EVERYTHING - else is either custom, aftermarket or GM (motor, trans).
So, what say the Jeep Gods? Is it a Jeep? Does the "soul" of the CJ live in the grille?
There's no definite answer. To me it's a matter of what it started with and the overall package. Yours most definitely qualifies by any scale I would use. The soul of what I'm looking at in that picture is all Scrambler :thumbsup:
My only bona-fide CJ-8 parts are the tailgate brackets, rollbar, and internal rollbar supports. (My old windshield hinges came from a CJ-8, but those went out with my YJ carcass.)
I have a handful of OEM CJ-7 parts: wiring harness, headlight buckets, hood, internal front fenders, steering column and wheel, voltage gauge, speedometer, tach/clock, wiper motor, glovebox door, Dana 300, center skidplate, 20 gallon fuel tank, full hard-door guts, swing-pedal assembly, gas pedal, heater/air boxes, power-brake booster, pitman arm, washer-fluid reservoir, left-side wiper pivot and the short arm, defroster vent things, front seat frames, power steering lines, one fuel filler neck.
My 401 probably came from an FSJ.
The 'soul' of a cj is the owner. They give it life, vision, use and purpose. I'd say you qualify both in the Jeep and Jeeper categories. (just maybe not the purist category :crazy: )
Not to be overly legalistic, but what does the title say? :)
does it have a Jeep grill? then you're good... There are buggies, with JUST a grill and its called a Jeep.
Have you given some thought where AMC got their original parts from? A lot from GM, Ford or whatever contractor could fill the bill at the right deal.
It's a Jeep.
A darn nice one, too.
Just Everyone Else's Parts is so true. If you get technical, mine's somewhat "as equipped".
My original engine was a GM Iron Duke. New engine- GM also.
Transmission- Jeep used many GM transmissions, Mine's GM.
Transfer case, axles- all Jeep sourced.
My biggest departure- PT Cruiser seats. Who cares, they're comfortable.
I say NO! Its NOT a Jeep... Its a horrible looking pile of parts that I am more than willing to take off your hands and take the blame for so you don't get accosted! ;) Feel free to drop it off anytime. :)
