1st choice AMC401
T-18/ D300 4:1
2nd choice Caddy 500
TH400/203/205 doubler or Th400/ Klune/D300 Seen a NP435 married up to a caddy 500 with a 4:1 D300 that was a nice combo
3rd choice Chevy big block
396, 427, 454, 502 T-18 or SM465/D300 4:1 or TH400/ Klune/ D300
4th choice AMC 360 T-18 D300 4:1
5th choice Chevy small block 350 465/D300 4:1
The big blocks, big stroke big bore motors idle down so much better than a chevy 350. a chevy 350 with TPI idles well at 800 and with good gearsing idles almost as well as a 401 or caddy 500 with so so gearing over the same obsticle
parts are pretty easy these days get a HEI conversion for the AMC from bulltear @$150
Get a one wire GM alternator $100
eliminate all other wires under your hood. now all you have to worry about is a water pump or radiator hose. everything else is cheap and available
