trust
PITA
- White Rock
- NM
Michigan doesn't do front plates and they don't give a crap what you have on the front, so that's the Alaska plate that was on it when I got it.
But do they require front plates? If not, who cares?Wow that's is crazy. CT would tow our shit as soon as we did that.
What is wrong with your EFI that causes it to now run during warm weather?
HESCO/MOPAR as near as I can tell, its done it occasionally since I installed it, as has everyone else I know who has done this system, usually with gas from the reservation, but now it has the same vapor lock symptoms even more frequently and with good, premium gas. a drive yesterday that took an hour to get there took 4 + to get home and I walked the last mile because it was quicker than waiting on it to decide to run.
I had major vapor lock issues with my mopar FI. It took me a year to figure it out. On what seemed like my 1000th test drive, i brought along my temp gun and discovered my problem. My fuel pump was mounted above the rear axel, right next to the fuel tank. The pump was getting really hot (180deg) from the axel and exaust, coupled with poor air flow. I moved the fuel pump to the back side of the tank, and havnt had a problem since. Now the temp on the pump is ambient.HESCO/MOPAR as near as I can tell, its done it occasionally since I installed it, as has everyone else I know who has done this system, usually with gas from the reservation, but now it has the same vapor lock symptoms even more frequently and with good, premium gas. a drive yesterday that took an hour to get there took 4 + to get home and I walked the last mile because it was quicker than waiting on it to decide to run.
People here run all sorts of things in front, lots of skinny German front plates on BMWs, for instance.
Point me to another thread of there is one.
One other idea.... What & where is your air intake? Hesco"s CAI they include with the MPI kit is terrible (it breathes nothing but hot air.. It should be called an HAI, not CAI)
I'm using a TJ 4.0 tube and box on the pass side away from the header.
Also, the box is connected to the grill at the CJ OEM locationwith same CJ OEM flexible tube rather than using the OEM TJ box "horn" that takes air from under the hood.
As an added precaution, I have some tape over the adjacent OEM hole in the top grill corner to minimize any under the hood air.
Jim
P.S. don't believe anyone on this board if they tell you I have a WAI. (Water Air Intake)![]()
For what it's worth, I'd look at finding a way to restrict and preferably eliminate under the hood hot air.My air intake is on the left side forward and consists of only an open element filter and tube to the throttle body, I'll look at repositioning it to the right side of the engine compartment, thanks
That is basically exactly what the factory CJ air cleaner did but most of the flexible hoses disappeared a long time ago.For what it's worth, I'd look at finding a way to restrict and preferably eliminate under the hood hot air.
