Work So Far
juiceman03070
new boston
nh
Got a good jump on things and have the Scrambler comming back to life.
Rebuilt carb
Fan blade was junk-new
Plugs
Wires
Rear Drums shoes wheel cylinders
Bushings Spring
Steering Dampener
Inline fuel filter
Donut on ex Manifold
Wheels Balanced
Registered and inspected so now I can run it until the snow falls.
Don't wait long do you? ;)
Great to know that the inside of that one is being made to match the condition of the outside... I couldn't even guess at the looks and comments you'll get runnign around up there in a Jeep that old in that condition... wow.
Road testing...
On and off road testing today , and couldnt be happier..
Motor kept an even 50lbs. of oil pressure at all times .. water temp well within rage.. all gauges worked well and the heater was needed as it only hit 50 in New Hampshire today.
Took it up to a local gravel pit and did a little bit of 4x4 just to check all the functions and was very tight and all worked well ..only problem is that it jumped out of reverse when a load was put on it (any thoughts)..
Ended up changing most of the dried out suspension rubbers and bushings underneath ,shocks brakes ect..
Goes down the road very well..
Again the frame and body are spotless.and will just need a little wire brushing before painting frame ...Will more than likely paint it original bronze color over the winter...
juiceman03070 said:
...Motor kept an even 50lbs. of oil pressure at all times ...
Dude, I hate to tell you, but something's wrong! CJs didn't get that much pressure when they left the assembly line ;D :D
That's incredible... great to hear.
Have to agree 50lbs or oil pressure and nothing said about leaking oil every where................you sure you have a Scrambler much less a Jeep? :eek:
You guys beat me to it....I was going to say that too............
Just not right...........
My fingers are the size of bananas 40 repeat 40 lbs...Typing skills are lacking also....
Anyway Im happy with the way the thing runs out.. :D
