Worn Out Body Mount Bushings - 1” Body Lift Kit
Griff04
Albany
Ga
Been a minute since I posted. I hope everyone is doing good.
The body mount bushings are in need of replacing, thought while I was doing them I’d do a 1” body lift kit, it would probably change the overall “stuffed look” I have going on since installing the suspension lift and 33x12.5s
I would assume this is pretty straightforward but I’m sure there will be some unexpected issues that will pop up.
Anyone have any recommendations on which body lift kit to purchase or watchouts for the installation? Will this cause the need for brake line extensions, auto transmission linkage issues, etc???
Happy Holidays Everyone
Not bad if you're already doing bushings. I did a JKS 1.25 BL on mine when I had the body off back in 2011 right after I bought it. Didn't make much difference on brake lines that I recall. I did notice that when flexing I had issues with clutch linkage not functioning properly. Make sure to use some sort of loctite(blue or red) or you'll lose a body mount bolt or 2.
You'll want to remove your fan shroud first, then re-locate the mounting holes afterward.
The body mounts are in need of replacing, thought while I was doing I’d do a 1” kit, would probably change the overall “stuffed look” I have going on right now since installing the lift kit and 33x12.5s
I would assume this is pretty straightforward but sure there will be some unexpected issues that will pop up.
Happy Holidays
The biggest concern when replacing the body mount bushings is getting the old bolts out. They have been known to break the captive nuts in the tub loose if they have corrosion.
The things that need to be considered are anything that is connected between the tub and frame (or its components). This would include the steering shaft, clutch linkage, transmission linkage, fuel filler hoses, radiator hoses, brake lines from master cylinder to proportioning valve, etc.
That being said, if you keep the lift reasonable most of those are a none issue.
I put on a 1" body lift and only needed to lower the fan shroud, and lower the mount for the clutch linkage at the tub.
The front brake lines run from the frame to the axle, so they aren't affected. I believe the rear line runs from a bracket on the tub to the center off the rear axle. I'm not sure if the 1" lift affected it or not, I had to move the mount on the axle because of my flexy springs.
I'm not sure if I had to do any adjustment on the parking brake.
Here are the instructions for a body lift kit to give you an idea of the steps involved.
http://www.quadratec.com/Assets/Installation/14629.pdf
On mine with an automatic, I had to a small adjustment to the shroud and a small adjustment to the automatic shift linkage at the base of the steering column, under the hood. I did have a lot of issues with rusted body mount bolts and rusted out mounts. It took a lot of repairs to those, but it was needed.
Does anyone with a 1" body lift think it's a hair too much, like I do? IMHO, I think a half inch would be perfect
None, other than a harsher ride vs rubber, just asthetically speaking
I absolutely love the 1", just enough room to give access for things without looking too tall.
You're taller, younger and don't have osteoporosis & a cracked femur ball in your hip 😂 I really need to get slider steps.
Dr said I need to slow down.
I said, not anytime soon so earn your money doc 😂, tru story. Kept me out of oakridge tho
Edited to add: I have camping, show & trail reservations for Fri-sun @ Blue Ridge Jeep Invasion (giggity)
Sorry for hijack
