You absolutely will not believe this!
Joe West
Arizona Virtual Jeep Club
Laurinburg
My Scrambler started on its own for the first time ever...
And you will not believe how :)
Yesterday I removed the carburetor to rebuild it and today I spent most of the day working on the interior replacing the heater control cables and some other small bits of interior work. One of the things I did today was rewire my oil pressure gauge (it had somehow been wired backwards) so after a hard days work and a quick shower, I walk out to the Scrambler and think "I'll bet i can test the oil pressure gauge by simply cranking over the motor" I hop in the Scrambler, insert the key, look at the oil pressure gauge and turn over the motor...
Imagine my surprise when it started! I'm like HOLY **** as I shut the key off and let my heart get back to normal ***!!!
I jump out, open the hood... and this is what I see:
attachment.php
So... can you see what happened? Yes indeed! Fuel, directly from the fuel line sprayed into the open intake manifold and the scrambler actually started and ran!
Unbelievable.... the first ever start and run for me and it was without a carburetor :)
Joe
Yep- you got a keeper there! Just think how good it will run with a carb!
All the luck.....
Some people can't even get them to run WITH a carb :rolleyes: ...
i walked up to my cousin working on a truck one time..i looked under the hood and it was running without an intake..i almost freaked..till i realized it was a diesel!!
With some of the carb problems I've encountered over the years you might find that it ran better WITHOUT one!
yet another bbd fix! get that posted on some of the web wheeling forums and you will have a mod named after you
Forget all that carb nonsense. I want to know where you got those trick custom vacuum line disablers.:wave:
Looks Like Your Making Great Headway On The Project. It Will Not Be Long Until Your Cruising. :)
Looks like the new "Joe West direct fuel injection" mod to me :thumbsup:
That's awesome!
