SOA or SUA for 35's
The lack of wheelbase/width and braking power would make me a little hesitant to try to use any CJ-8 as a tow rig for much more than a medium-size boat... just my opinion.
Eric,
Did yours come with the power brakes? If so, how well does yours stop? I think I need to look at the braking system on this.
Does anyone know if the YJ rears will fit on the front? If so, is it the same setup that is needed for the YJ conversion?
Yes, power brakes, they were questionable when I went to 33s. I did an axle swap to Waggy axles and added the Vanco brake booster at the same time and now it will stop better than anything else I own (without ABS though of course), so it will lock up my 35s.
There's a couple junkyard ways to swap boosters, search around, or you could just try to score a nice Vanco or navajo unit new.
Can't help on the YJ swap you're talking about.
Cheers Eric.
Might look at doing a servo swap. On your front brakes, Are your calipers covering the pistons? or are mine the wrong size? The pads only sit on half the piston, but cover all the disc. I'm thinking the pads/discs might be the wrong ones.
Does anyone know if the XJ Dual Diaphragm booster and master cylinder will fit? Or is the TJ similar?
Cheers Eric.
that sounds like the stock setup, the pad doesn't cover the full piston IIRC.
For what it's worth I am running the RE 4.5 with a 1 inch body lift and 37 Krawlers. My rear wheel opening has been radiused a bit with the addition of the rear crusher corners and 3 inch flares.
Rich: how do I get my pictures to show in the post as opposed to just being attached?
Are those H2 rims? Any pics of it flexed?
Found this on another forum:
I posted this to the Zuk BBS awhile ago.
OK, here are the spring rates:
'87-'90 YJ:
4 leaves in the front only, 39.75" long, and a rate of 128 pounds/inch stock and 203 pounds/inch optional (6 cyl and/or hard top).
Rear has 5 leaves stock and 6 leaves optional, 46" long, and a rate of 170 pounds/inch stock and 237 pounds optional (6 cyl and/or hard top).
'91-'95 YJ:
4 leaves in the front only, 45" long, and a rate of 113 pounds/inch stock and nothing optional.
Rear has 5 leaves only, 45.6" long, with a rate of 170 pounds/inch, nothing optional (no heavy duty).
My cj
Yes they are H2 rims. No flex pictures since it is still under construction. Lost of folks run this combo with good results. The front springs are CJ length but YJ width. Not sure of the rate but they are off the shelf Rubicon Express 4.5 inch lift. Since I am running the 401 V8 and a nose heavy winch I might need to add something up front. I flex clecked it when I adjiusted the bump stops and all seems well.
The springs in the RE kit are their RE1450 for the front and RE1451 for the rear. The 1450 has a 227 spring rate and the 1451 has a 242. I found out while emailing their tech support. I need to pull my front's and switch tem to 1451's; theight from my V-8, winch and bumper has got me "nose down". I want it up about 1.5".
Springs
Good info Johnny. I am not sure which part number I have in the front, but I remember telling the guys at RE that I had a 401 and a big winch so they may have sent the bigger ones.
I am also running that gigantic Clark 285 SV transmission which weighs in as much as the 401. Grantshire calls it the School bus transmission since it comes from a C 60 GMC
That being the case, I'd either run the 1451's up front and the 1450's in the rear or call RE and try to swap the 1450's out for some 1451's before you use them so you don't end up where I am.
Joe,
You need your pictures hosted somewhere like photobucket then paste the image code into your post. Should be something like: http://i42.photobucket.com/albums/e345/Grantshire/2-9-09049.jpg
Richard
I am in the process of buying the RE 4.5 and just wanted to know before i purchase. Should I get the 1450(227) or 1451 (242) upfront? What is the difference between both springs? Is there a big difference between both other then maybe a bit more stiffness on the 1451? Will the 1451 not sage as much? Comfort level? Just trying to understand? Not carring to much weight in the front a 258 with a winch mostly street and light off road. Thanks
i am very interested in this 4.5 rubicon express lift,i think my 4 inch lift is a cheap rancho or rugged trail and it is detroying my back,i will be swapping the 258 with a 360 and i what to keep the stance of my jeep or like john n (happy b-day) have the nose up a little
is this my answer!!!
Just got off the phone with the rep at Rubicon Express and after going back and foward on questions he mentioned that I should go ahead and add the 1451 leaf spings in the front as well. Normally the RE comes with the 1451 spings in the rear and the 1450 springs in the front.
My questions:
If I do decided to get the 1451 leaf springs in the front will my 258 and winch keep my jeep horizontal or will I have my front of my jeep looking higher then the back of the jeep.
Anyone have this set up? Anyone have the 1451 leaf springs by RE both in the front and rear?
Anyone have the RE 1451 leaf spings in the front aswell? Normally they only come in the stardard package with the RE 1451 in the rear and the RE 1450 in the front.
