that sounds like the stock setup, the pad doesn't cover the full piston IIRC.Cheers Eric.
Might look at doing a servo swap. On your front brakes, Are your calipers covering the pistons? or are mine the wrong size? The pads only sit on half the piston, but cover all the disc. I'm thinking the pads/discs might be the wrong ones.
Not sure, I think it's pretty common.How wrong is that???
For what it's worth I am running the RE 4.5 with a 1 inch body lift and 37 Krawlers. My rear wheel opening has been radiused a bit with the addition of the rear crusher corners and 3 inch flares.
Rich: how do I get my pictures to show in the post as opposed to just being attached?
Yes they are H2 rims. No flex pictures since it is still under construction. Lost of folks run this combo with good results. The front springs are CJ length but YJ width. Not sure of the rate but they are off the shelf Rubicon Express 4.5 inch lift. Since I am running the 401 V8 and a nose heavy winch I might need to add something up front. I flex clecked it when I adjiusted the bump stops and all seems well.
Good info Johnny. I am not sure which part number I have in the front, but I remember telling the guys at RE that I had a 401 and a big winch so they may have sent the bigger ones.
I am also running that gigantic Clark 285 SV transmission which weighs in as much as the 401. Grantshire calls it the School bus transmission since it comes from a C 60 GMC
That being the case, I'd either run the 1451's up front and the 1450's in the rear or call RE and try to swap the 1450's out for some 1451's before you use them so you don't end up where I am.
