Rear Sliders (windows)
trust
PITA
White Rock
NM
who has the sliding rear window in their hard half cab and how do you like it? does it help with ventilation, especially in the foot wells? I get really hot sometimes in the cab and don't want to go topless on a couple hundred mile highway transit. I had thought of a vent from a TJ tailgate in the bulkhead to help flow through and then in looking at Jeff's retro thread I thought why not just go with a slider.
so, any thoughts? Is this better in the body or some other forum?
thanks
I don't know about a vent in the body or bulkhead, but I do have a rear slider. Mine came from Matt. I really like having it and it does help with ventalation. I'm not sure what it does for the footwells, but I really want to put a valve in the heater lines so I can cut off the coolant flow to the heater core in the summer. That should help the most.
FJ40 Foot Vents
I always liked the floor vents that could be kicked opened with a foot that were standard on the old Toyota Landcruiser FJ40's. They really work to get that cross ventilation going.
Jeff
Jeff
I had an older truck with a sliding rear window. It seemed that with the slider open, air was sucked from the rear window across the cab and out the side windows. It actually seemed to "cool" me more when I ran with it closed.
I know that the floor vents work incredibly well (at least on other vehicles). I have been told they work well on our CJs too. So, I found a place that makes them and bought one. I can't wait to install it and try it out. Attached is a forum link with pictures of what they look like installed and where I bought mine:
http://www.qualitycraftcorp.com/aem/products.htm
http://www.jeepforum.com/forum/showthread.php?t=647784&page=3
Jeff
I loved those vents in my FJ40.
Truck
sliders and vents
In regards to the ventilation, you do get a a good amount of ventilation with the sliders but its mostly in the upper part of the cab. On the CJ it seemed like there was a lot of heat coming off the floor.
The vent you are referring to in Jeffs posting that they put on the the tailgate of the TJs isn't really a "open flow" vent. It has some rubber flaps on it and only really opens under cabin pressure. (ie doors closing, or airbags going off). So, I don't think that type of vent on mounted on a CJ bulkhead really isn't going to allow much "free flow" air flow. If you mounted the plastic part of it and then removed the rubber flaps it probably would allow some extra air flow. That might work to allow some better air flow down low. Or some other type of vent mounted on the bulkhead. The problem with mounting anything on that bulkhead is it has curves ribs on it, and trying to mount anything on to those curved ribs will be pretty challenging.
We (GR8TOPS) have finally finished the reproduction OEM CJ8 bulkheads in fiberglass and have them available. We did leave the center section of the reproduction bulkhead totally flat for two reasons, one of them being the possibility of just what we are talking about. I left it flat so if someone wanted to mount one of the TJ style vents on there they could to relieve cabin pressure when the doors are closed. I also made it a flat surface to have a place to mount the GR8TOPS logo on a different version of the bulkhead we made just for CJ7 or YJ's.
I've got some pictures somewhere that I will upload later today.
Anyone else mounted any kind of vents onto the bulkhead to help with air flow?
Matt
3 panel slider vs 4 ?
Also. What would everyone think of a 3 panel slider inside of the current 4 panels?
I've found the 4 panels to be a bit cumbersome for the following reasons:
1. you have to push the glass to either side behind the headrests on the seats, and once you lean back on the seats the cabin is so small there is usually pressure on the sliding windows that you have to lean forward to move the window or close it.
2. 4 panel sliders always have a bar right in the center that is highly visible in the rear view mirror. As small as the cab is, that bar in the center of your rear view mirror is fairly prominent.
3. trying to latch the latch and actually lock the 4 panel is a coordination challenge. You have to pull both sides in to the center then fumble with that latch/lock. 3 panel pull to one side and it automatically locks as you slide it over into place. (most models)
4. in a certain sense, 3 panels seem to be a little bit more secure - granted if someone wants in a jeep to steal something, they are going to get into the jeep regardless.
my manufacturer for the sliders does not currently make a 3 panel for the CJ8's but I have approached them about ordering a special run of 4 panels. But, it you have to have a minimum manufacturers run of them.
I agree with your points on this Matt.
Agreed about the 4 panel being in the rear view. Also, to address the earlier comment about ventilation... it definitely is cooler however I see no benefit on the floorboard. :shrug:
I had the sliding rear window on my old 85 Scrambler and loved it, I don't think I ever closed it. :thumbsup:
I should have never sold it:banghead:
Thanks gents! I appreciate the input, it confirms what I more or less knew, or thought anyway.
Thanks for the link to the footwell vents, I had them on my 74 CJ 5 and they do work great, I had looked for some but wasn't able to find them again.
I also did the heater hose valve John, didn't help as much as I thought it should, a lot of exhaust and drivetrain heat.
Nice looking ride Mike, very nice
thanks guys and happy Christmas or whatever you choose to celebrate
Sliding Glass
Does anyone know where I can find/buy the rear half top sliding glass window?
Thank you,
Chris
Thank you,
Chris
From our site owner, Matt. He sells them through Gr8 Tops....there should be an ad on here somewhere.
I put a Valve on the heater hose so no hot water to the core in the summer. What a difference.
