...but instead of starting forward, the finicky old CJ’s Thornbirds broke loose and caused the jeep to slide sideways along the slope of the road until the passenger side tires crested a roadside ditch. Itchyball, whose fears increased with the off-camber attitude, cut the wheels to the left and floored the accelerator pedal. It was all in vain; his Jeep moved, it is true, but it was only to plunge to the opposite side of the road into another ditch, only larger and mud-filled. The mechanic now worked both clutch and gas pedals of his Jeep, which bounced and bucked out of the bog, but came to a stand just by the bridge, with a suddenness that had nearly sent his driver sprawling through the windshield. In the dark shadow of the grove, on the margin of the brook, he beheld something huge, misshapen, black and towering. It stirred not, but seemed gathered up in the gloom, like some grossly deformed CJ with a long bed, ready to spring upon the traveller.
The hair of the affrighted maintenance technician rose upon his head with terror. What was to be done? To turn and fly was now too late; and besides, what chance was there of escaping ghost or goblin, if such it was, which could ride upon the wings of the wind? Summoning up, therefore, a show of courage, he demanded in stammering accents—“What are you?” He received no reply. He repeated his demand in a still more agitated voice. Still there was no answer. Once more he gripped the worn leather steering wheel, and, shutting his eyes, broke forth with involuntary fervor into a Jeep jingle...quietly singing "Only in a Jeep" to the commercial's tune. Just then the shadowy object of alarm put itself in motion, and stood at once in the middle of the road. The figure appeared to be a Jeep CJ of large dimensions and powerful frame. It made no offer of molestation or sociability, but kept aloof on one side of the road, crawling along on the blind side of Itchyball’s aging CJ, who had now got over it’s previous rough idle and slowly made it’s way.
Itchyball, who had no relish for this strange midnight companion, and bethought himself of the adventure of GreatCJ8 with the ghostly Scrambler, now quickened his pace, in hopes of leaving him behind. The stranger, however, quickened to an equal pace. Itchyballs let up on the gas, thinking to lag behind—the other did the same. His heart began to sink within him. There was something in the silence of this unwanted companion, that was mysterious and appalling. It was soon fearfully accounted for. On mounting a rising ground, which brought the figure of his fellow-traveller in relief against the sky, hood opened and resting against the top of it's windshield frame. Itchyball was horror-struck, on perceiving that he was headless!—but his horror was still more increased, on observing that the head, which should have rested on the engine block, was set in the Scrambler's bed; his terror rose to desperation; he rained a shower of kicks and blows upon the accelerator pedal; hoping to give his companion the slip—but the specter started full jump with him. Away then they dashed, through thick and thin; stones flying, and mud spraying at every bound.
They had now reached the road which turns off to Jeepy Hollow; but Itchyball’s Jeep made an opposite turn, and plunged headlong down a hill to the left. This lead to a rock-strewn trail, shaded by trees for about a quarter of a mile, where it crosses the bridge famous in goblin story, and just beyond swells the green knoll on which stands Itchyballs' garage. As yet, the top end power of the old CJ's 401 had given it's unskillful driver an apparent advantage in the chase; but just as he had got half way through the hollow, the bucking of the Jeep as it hit the trail's rocks caused the unseatbelted Itchyball to bounce around the cab violently, affecting his escape. Even as this happened, the CJ's flimsy vinyl top became undone, flapping and snapping in the wind. Finally, it separated from the vehicle. It fell to the earth and he heard it trampled by the Swampers of his pursuer immediately behind him.....
...to be continued...
