1985 cj8 build
It's 5.3L/4l60e time!
Well the 5.3L/4l60e fairy stopped by my house today.
I after doing more research and saving a few pennies
I decided on putting a 5.3L/4l60e drivetrain in the wifes
cj8. It was just dropped off today. so I'm hope that my goal
of a full rolling chasis will happen before the end of the year.
O and the house painting is almost done (95.9% done)!
here's some pic's:
Congrats on the purchase. I am jealous. That is the next phase of my project but got pushed back (way back) when I got laid off last June.:banghead: I guess I will have a lot of information to look back on whenever I do get to do it.
Looks great! What's that out of? I like the looks of the cover.
Thanks! It's out of a 2008 gmc sierra 1500. It only has 12,000 miles on it. I got it from schram auto parts in Waterford MI. I can't wait to get this thing in and running.
How's your build going Randyzzz? It has been sometime since i checked in on your build. My next step is motor mounts and a tranny to transfercase adapter. I haven't advanced adpaters or Novaks? Novak's kit replaces the 4l60e's output shaft. And the advanced adapters kit replaces the input shaft in the dana 300 + you have to cut the 4l60e's output shaft . Any remarks?
7jeeps7kings
I have a remark.
You may want to look into the Stak transfer case. They can be bought to bolt to your transmission. Depending on what mods you want to do to the d300, it may not cost any extra. Add up adapter + gears + outputs + rebuild. Now if you're just going to run a stock case you'll be much cheaper with the d300.
I have a remark.
I plan on running the stock dana 300. I've owned a few jeeps with this setup and have had no problems! Staks makes a nice moster box (as they call it) transfercase. But $3,000.00 is some money to spend on a jeep my wife is going to use as a summer toy. they don't list an adapter for 4l60e to a dana 300. I'll call because they do mention something along the lines of " we have input shafts for the dana 300 for all gm transmissions". and they didn't have any prices on their adapters? As of right now I plan on going with the novak adapter kit.
thanks,
7jeeps7kings
7jeeps7kings
Progress has been a bit slow on mine due to weather and a temporary distraction/winter driver, but I should be back on it this weekend.
I went with Novak. I really like their products and Eric has been a great help to me. I had to replace the output shaft because there isn't any aftermarket source for a 241OR input shaft. Regardless, I like the simplicity and quality of the Novak adapter. Gives you a good chance to make sure the trans is ok while you're at it.
Thanks. I hope the tranny is ok. It only has 12,000 miles on it!LOL.
7jeeps7kings
update
Well I have been on the hunt for parts. I am still collecting cash
so far I have found a set of the M/T Challenger mag rims 15x8.5" (still looking for 15X10").
I have some more updates coming but need more money and time.
LOL
7jeeps7kings
drivetrain
well I have been on the hunt. I know that I was asking about adapters earlier in my thread.
but I think that has changed. both AA and Novak state that if you stay with the stock front driveshaft you will have no clearance issues.
Well I have been using my search button so much this past couple of week I think I broke it.LOL! Not really. all the guys I have talked to
on the phone and the builds I have found either say: driver side drop, no clearance with the dana 300 with stock skinny front drive shaft,
atlas(expensive),np 205, and or don't do the dana 300 adpater passenger side drop. I know that this is not a new problem. and it has
been well docummented on the net. but it is time for me to decide what I'm going to use. here is some of the info I have found.
-Advance adapters sells a kit for the 4l60e to dana 300. I like this kit because it replaces the input shaft in the dana 300 to match the
27 spline of the 4l60e. it also hooks up the gm vss sencor. but you have to cut the 4l60e's output shaft down to size. that I don't like.
and they also mention depending on setup you might have to use small diameter front driveshaft.
cost: $517.50
http://www.atlas-tc.com/pdf/50/50-0432.pdf
-novacks also sells a kit for the 4l60e to dana 300. I don't like this kit because you have to pull the tranny apart to replace the rear out
shaft of the 4l60e and it decreases the spline count to match the dana 300 (23spline). and you still have clearance problems with a
skinny front drive shaft.
local tranny shop :$140.00 for tailshaft replacement
adapter:$547.98
http://www.novak-adapt.com/catalog/kit_4l63.htm
-jb conversions sells one too but I could not find a listing on thier site. here is a link to thier website showing how tight it is with the
700r4/dana 300:
http://www.jbconversions.com/products/adapters/1001.php
-dana 300 is 8.5" from the center of the input shaft to the center of the front drive shaft
output.
-atlas II is 9.5" from the center of the input shaft to the center of the front drive shaft
output.
-np205 is 9.5" from the center of the input shaft to the center of the front drive shaft
output.
-dana 300 is only offer in passenger side drop. but you can either flip this transfer case for driverside drop or replace the housing
with a stak's and make it a driver side drop tc. http://www.stak4x4.com/
-atlas II tc can be bought either driver side or passenger side drop.
-np205 came eitherway from the factory(passenger side or driver side drop)
-dana 300 come with a 2:62:1 low range. unless you upgrade to aftermarket 4:1($988.95 for kit)
-atlas II comes with what ever you want (for the most part. just bring the cash)
-np205 comes with a 1:98:1 low range. unless you upgrae to aftermarket 3:1($1349 for kit)
I really would like to stay with the passenger side drop. otherwise I will have to go driver side drop and find a new front axle.
I think I'll look some more. but if you have any advice lets here it. and pic's too.LOL
thanks,
7jeeps7kings
You're running into exactly what I ran into with my build. That's why I finally decided to go with a driver's side drop front axle. I got lucky and got some great deals on parts, too. I went with a NVG241OR transfer case, out of a Rubicon. It has a 23 spline input, so the Novak adapter was the best choice. (There are no aftermarket inputs for the NVG241OR.) I used a J truck widetrack front D44 narrowed on the pass side so I didn't need to outboard. (Well, not 100% true- the housing was not narrowed the proper amount so I ended up outboarding 1/2", but if you're starting from scratch you should be able to get it dead on.)
Bottom line- with the drivers side drop and the engine perfectly centered in the frame I can fit a 2 1/2" front shaft easily.
It sound like I am going to have to go this route. But I am fighting it. LOL. I am in the process of figuring out numbers right now. I know I want to stay with a gear driven transfercase. so it's either going to be a dana 300, np205, or an atlas. although I'm really not looking to spend the money on an atlas for this build. I will most likely buy a stak's replacement housing for the dana 300, or find a driver side drop np205. I still have to talk to my axle guy. so I can figure how much it is going to cost me to cut an axle to fit. It will come together this is just a little bump in the road. I kind of knew there was a problem with the passenger side drop dana 300/4l60e. I just didn't know how bad of a problem. And I wasn't sure if guys were running into this problem because they were clocking the transfercase flat. which I am not plannning on doing. I really haven't seen any pic's of guys builds that are running the 300/4l60 combo that did not clock the tc flat. It seems everyone is clocking them flat. So I still wonder if clocked you tc in the stock position if it is still that close to the trans? So if anyone out there in jeep land has there dana 300 behind a 4l60e and did not clock the tc flat. please post your pic's. So in the end whatever makes this jeep the most functional for the price wins. Because I don't like to see jeeps that look cool but don't function. I am not one of those guys with a $8,000 paint job and chrome everywhere with 44" tires and a stock drivetrain. I like my jeeps to look right and function right. we will see I am still crunching numbers.
7jeeps7kings
I probably have a pic here somewhere of the next best thing. A TH350 has the same clearance issues. I put a TH350 with a 300 in my Jeepster, using the stock D30 front end. I have a 2" lift and clocked the D300 close to stock- in other words hanging way down . The driveshaft is one of the stock "pencil" shafts, and it barely clears. 1/2" at the back down to 1/4" at the front. So...it can be done but I wouldn't suggest it for a V8 or tires over 31".
I'm not sure what the Stak replacement housing for the 300 gets you. You can just flip the d300 using the stock case. I think somebody makes a ring for this now. I did it some years ago and used a normal clocking ring, turned around backwards and retapered. You can either use cable shifters, or build a linkage to sneak around under the driveshaft, as the shift rails will be under the driveshaft when flipped.
I have also seen this. If the clearance issue is between the driveshaft and the transmission pan, the pan can be notched. You would have to check what can interfere inside the pan, and see how far you can go.
I have also seen a 2-piece front driveshaft used for clearance issues. This has the added benefit of increased ground clearance.
here's stak's website:
I'm not a big fan of the two piece driveshaft(shaft/pillow block/shaft). I would go driver side drop before I would do a two piece front shaft. IMO. it does work and I have seen it on other jeeps. But I would like to avoid that at all cost. If this was a rock crawl I would have no problems with it.
thanks,
7jeeps7kings
