Jeff's 2010 Project...
You have mentioned the trailer out of the rear end of a wrangler. Personally I like the idea (single axle only however) but I thought I would let you know that I saw one here in Utah for sale, it was built out of a YJ tub, and he had it for a very long time. No idea if he ever sold it, but he was asking something int he area of 350-500 for it (can not recall for sure) and it had very little interest. He even had the gas tank still in it, and a pump put on the thing so that it could pump the gas into your jeeps tank (which I thought would be really cool for an overland or expedition type trailer. He did have the CJ style roll bar still mounted in there, and I thought with all of that, and then someone like you could put in a hard top cut it down, build a front window like the rear in the gaucho, and you would have a really cool trailer.
Anyhow, I thought it was great, but I got the impression that I was one of the few...
Good luck to you!
Brian
Jeff, It seems to me that you need a trailer for many of your projects. You also seem to need one that can hold some weight. I would build the double axle trailer as it is something you will use and no longer have to rent something. As it seems you will continue to do other projects this seems to be the most practical option. Plus it gets the stuff out of the way.
Truck
Truck
Yes, you're right I do, and you've been witness to that need, who is this happy guy?
attachment.php
I used U-Haul trailers a number of times on both the Gaucho and the Retro project, this next photo was taken 11 months ago as I was bringing a YJ tub home from Ed's in Scranton:
attachment.php
I need to own a trailer that's large enough to hold a Jeep tub, that would handle almost all of my project parts fetching.
Of course sometimes I need a tow dolly too, but that's less common so I can rent that when I need it:
attachment.php
So yes, one of the trailers I need to build has to serve my parts collecting for future builds. Two axle would be good for that, and probably I shouldn't base that on a Jeep tub, because it would need to be larger than that in order to hold a tub.
Good luck to you!
Brian
Brian,
The thing I don't like about most trailers made from Jeep tubs is that they're too small inside to be really useful - the stock Jeep inner fenders take up too much room. One of my ideas is to remove the inner fenders and replace them with Scrambler-like inners (actually even a bit smaller than Scrambler inners), so to increase the cubic foot capacity inside the trailer. Also many of them are really short, being made from just the back half of a single tub with a front wall slapped on, I would make mine a bit larger.
One reason I hesitate to start making trailers right now, though, is that the back halves of the tubs I have could be put to really good use making custom Jeeps. The back half of the LJ tub cold be used, for example, to stretch an LJ to Scrambler length. The back half of the YJ tub could be used to build a stretch YJ or a "CJ Unlimited". Seems like those would be more interesting to build than trailers.
what about a trailer that can haul a Jeep tub... BUT can easily be converter to be a dolly with storage space on it? know what i mean?
I know what you mean but I'm having trouble envisioning how it would work. Tow dollies are extremely short, and have a very wide wheelbase with an underslung axle that's very close to the ground; cargo trailers need to be longer to be useful and generally higher from the ground than a dolly.
I need a dolly very infrequently, so I'll leave that to U-Haul. Fetching body parts, tubs, frames, etc., is much more common for me to do on a project, maybe 3, 4, 5 trips per project, so a cargo trailer would be the one to build.
So now it's time to decide what I do next; I've got about a month of stuff to keep me busy but in January I'm sure I'll be bored and looking to start a next project. Here are a few possibilities I'm considering, but I probably won't make a final decision until sometime in January. These aren't in any particular order.
Option 1: Finish the Gaucho. I could change my mind and decide to finish it myself instead of selling it. I'd need to find a donor CJ-7 to provide all the bits necessary, and I'd need to decide what engine/transmission I'd like it to have. Color would probably be Chrome Yellow, or possibly one of the TJ or YJ yellow colors. Two weeks ago I would have told you there would be zero chance of me doing this, but now that the Gaucho is finished, I'm having second thoughts. The Gaucho has exceeded my expectations in many ways, and could easily be finished into a show-quality truck. Considering how much work it's taken me to get it to this point, building it the rest of the way seems pretty easy.
Option 2: Build one or more "Jeep tub" trailers. When I was picking up parts for the Gaucho project, I bought two Chevy pickup beds that had been converted to trailers - a longbed and a shortbed. Both of these were on decent trailer frames. I've also got the back half of the LJ tub from the Retro, and the back half of the YJ tub from the Gaucho, and a bunch of other tub parts, like top rails, so I've got most of the major pieces required to build both shortbed and longbed tub trailers. Here are some concept drawings, and some photos of the tubs, and the short- and long-bed frames I've got cluttering up my back yard. One of these days I have to do something with these parts, can't just let them sit here forever...
Option 3: I've always thought that Jeep factory hardtops look like upside-down bathtubs, so I've always wanted to build a completely custom hardtop with a little more style. If you've read some of my other threads, you've seen the modular design I've come up with for a hardtop system - using a series of common components, custom hardtops could be assembled for everything from Jeep pickups like the Gaucho to standard length CJ/YJ/TJ tops, all the way to LJ and Scrambler tops. The longer tops, like the LJ and Scrambler, could have a normal or an extended-height roof. I've figured out the engineering so the same parts could build a top for a CJ/YJ or for a TJ, dealing with the different methods of windshield top attachment. Rear door would be a swing-up hatch for the CJ series tops, but for the YJ and TJ series tops, the rear door would consist of a "half upper" that attaches to the stock tailgate, similar in concept to how a hard half-upper attaches to a half-door. I've worked out all the design and engineering issues for this project, and done detailed drawings for most of the components, here are just a few concept drawings...
Option 3a: Once the top molds were built, there would be any number of custom projects I could build with these tops. For my own use, I'd like to build a full-length Safari top with the extended-height roof for a 2005/2006 Wrangler Unlimited.
Or, Option 3b, if I decided to build another custom Jeep, I could build a long-wheelbase YJ with a Safari top in either pickup length or the full-length extended roof version, for example...
If I do the Safari top project, I'd start by building a pickup cab first, it would be easiest to do a smaller top first, plus that would give me all of the complicated modules I'd need to build the full-length top as the second phase of the project.
Option 4: Of course there's always the Mahindra Marshall 4-door idea, I would have my friends in India buy me a Marshall, disassemble it and send me the complete body. Over here, I'd build it onto a 2004/2006 Wrangler Unlimited chassis, so it could be a DOT-legal vehicle in this country and have all the benefits of the proven TJ mechanicals. But I think I'll hold off on this idea for some year in the future.
I'll be pondering this decision through the holiday season with the idea that I'd probably start whatever new project I decide on in mid-January. As always, your thoughtful input is welcome. :)
I like your modular top idea but would also include a "fastback" option similar to HUMVEE's for those who want a full hardtop but not the CJ7 squareback look. Done the right way the sides could be removed for summer driving with a bikini over the middle section. I also like your two axle trailer concepts.:cheers:
Everything you have done so far has been first class and well documented/posted :bow::bow::bow: so I look forward to the next "build".
yeah makes sense... saw a picture in my head... looked cool, but wouldnt work.
I'm curious. Would not a tandem trailer capable of hauling a tub also be capable a vehicle on it? Why would you need a dolly at all if you had that car hauler trailer?
Sorry, just a little confused here... :U:wave:
Tubs only weigh what, 400-500 pounds? Building something to carry the size of a tub, or say 1000-1500 pounds, would be fairly straightforward with the parts I've got; building something to carry the 3000-4500 pounds and size of a full Jeep would be a whole different size, scope and cost project, and couldn't use the parts and materials I have on hand. Given the cost difference of building a larger/stronger trailer vs. the cost of renting a tow dolly once a year, if that, for $45, the decision seems simple.
Gotcha...
I guess the confusion still hanging around for me is why build a tandem trailer for four to five hundred pounds?
Gotcha...
I would built it for something like 2000 pound capacity. Could do that with a single axle or a tandem... but tandems pull so much nicer at highway speeds in my experience. But could do either. Depends I suppose on what tire size I'd build for - if using smaller tires, a tandem might be better.
After watching this build for a while, I would think it would be heart breakin for you to see somone chop it up and do some shady fab work or turn it into an exo caged rockcrawler.
My thought would be to finish it. With CJ WT axles or FSJ Dana 44's and the SD33 Nissan diesel w/727 auto that pavementpounder has (he also has the custom mounts from 1x1speedcraig's bio diesel project that the engine came from).It would make a nice bolt in diesel set up.
I think a trailer to use for utility purposes can be obtained quite readily and not worth all the custom fab to scratch it up hauling junk parts around. The tub parts I would think are harder to come by in good shape.
As far as the tops, neat idea but not my cup of tea.
The Mahindra would be pretty neat though!!
Anyhow,I look forward to seeing the next project.
Jeff,
You never cease to amaze, I'm not going to vote for any of the projects as each of the prevous ones have been a gold mine of good tips and techniques, although they are wasted on me...... I will suggest that if you do decide to finish the Gaucho, and you deire to remain as close to original, wasn't the original a narrow trac? If you want to build it for fun and not necessarily duplicate the original, I'd go with a 4.0/AW4? and a D300 with a scout or narrow trac Wagoneer 44 in the back and the stock CJ WT 30 warmed over up front, or 360/auto trans/D300.
If you decide not to bother with finishing it I would sure love to bring it down here and build it, or rather I would love to have it finished and down here for my DD, but I know that isn't very likely uless my retirement plan works out (come on powerball!!!).
Whichever way you decide to go I'll be looking forward to the build and enjoying every step of the way
Jeff,
Thanks Terry. If I decide to finish the Gaucho, I'm actually not too concerned about keeping it any closer to the original than it already is - it's as close to the original as I wanted to make it, and in finishing it, I'd like to modernize things to make it a better daily driver, so I would most likely want to do an EFI 4.0.
I would definitely want to put an EFI 4.0 in it.
I'm not sure which transmission I'd want, I think the easiest way to get a 4.0 setup to put in would be to buy a 91-95 Wrangler as a donor because there are many other parts I could use from the Wrangler in finishing the Gaucho. A YJ would come with an AX15 5-speed or a 3-speed automatic. I like the idea of an AW4, but that would have to come from a Cherokee donor which would add complexity to the parts sourcing and assembly.
I built the Gaucho for WT axles, NT's won't fit around the bed in the back. The bed is only 44 inches wide inside as it is, I didn't want to make it even narrower for the original NT's, so I went with WTs'.
I think what I'd probably do is 91-95 YJ 4.0 EFI, whichever trans came with that in the YJ donor (auto or manual), a Dana 300 adapted to the YJ transmission, and CJ WT axles.
Right now I'm down to the following three options:
1. Sell the Gaucho and do the hardtops. I haven't got any serious interest from anyone in buying it yet although I haven't really advertised it for sale other than a few posts in forums.
2. Finish the Gaucho first, then do the hardtops later.
3. Do the hardtops now, then the Gaucho. I could use the Gaucho as the development platform for the half-cab hardtop.
I'll probably decide by the end of the year...
NT Waggy--wider than a WT CJ, it's what I'm running. Ideal CJ width IMHO.
Yeah but if I would have to go to the trouble of outboarding the axles, I might as well just run the axles that I'd get along with a YJ donor that's I'd be buying for the EFI 4.0 :)
If you go with the cut down Waggy then you get something in between the WT CJ axle and the YJ width.
58.5" IIRC.
Check out the FAQ on front axles and see what all is there.
Then you can go with a Isuzu Rear 44 early model and get disk brakes.
Carl
