hogi
- Rehovot
- IL
Just dont forget the retro willys wagon [https://www.cj-8.com/forum/showthread.php?t=18796&page=50] or the Willys Wagon top on Scrambler body.
Just dont forget the retro willys wagon [https://www.cj-8.com/forum/showthread.php?t=18796&page=50] or the Willys Wagon top on Scrambler body.![]()
Jeff, It seems to me that you need a trailer for many of your projects. You also seem to need one that can hold some weight. I would build the double axle trailer as it is something you will use and no longer have to rent something. As it seems you will continue to do other projects this seems to be the most practical option. Plus it gets the stuff out of the way.
Truck
You have mentioned the trailer out of the rear end of a wrangler. Personally I like the idea (single axle only however) but I thought I would let you know that I saw one here in Utah for sale, it was built out of a YJ tub, and he had it for a very long time. No idea if he ever sold it, but he was asking something int he area of 350-500 for it (can not recall for sure) and it had very little interest. He even had the gas tank still in it, and a pump put on the thing so that it could pump the gas into your jeeps tank (which I thought would be really cool for an overland or expedition type trailer. He did have the CJ style roll bar still mounted in there, and I thought with all of that, and then someone like you could put in a hard top cut it down, build a front window like the rear in the gaucho, and you would have a really cool trailer.
Anyhow, I thought it was great, but I got the impression that I was one of the few...
Good luck to you!
Brian
what about a trailer that can haul a Jeep tub... BUT can easily be converter to be a dolly with storage space on it? know what i mean?
So now it's time to decide what I do next; I've got about a month of stuff to keep me busy but in January I'm sure I'll be bored and looking to start a next project. Here are a few possibilities I'm considering, but I probably won't make a final decision until sometime in January. These aren't in any particular order.
Option 1: Finish the Gaucho. I could change my mind and decide to finish it myself instead of selling it. I'd need to find a donor CJ-7 to provide all the bits necessary, and I'd need to decide what engine/transmission I'd like it to have. Color would probably be Chrome Yellow, or possibly one of the TJ or YJ yellow colors. Two weeks ago I would have told you there would be zero chance of me doing this, but now that the Gaucho is finished, I'm having second thoughts. The Gaucho has exceeded my expectations in many ways, and could easily be finished into a show-quality truck. Considering how much work it's taken me to get it to this point, building it the rest of the way seems pretty easy.
Option 2: Build one or more "Jeep tub" trailers. When I was picking up parts for the Gaucho project, I bought two Chevy pickup beds that had been converted to trailers - a longbed and a shortbed. Both of these were on decent trailer frames. I've also got the back half of the LJ tub from the Retro, and the back half of the YJ tub from the Gaucho, and a bunch of other tub parts, like top rails, so I've got most of the major pieces required to build both shortbed and longbed tub trailers. Here are some concept drawings, and some photos of the tubs, and the short- and long-bed frames I've got cluttering up my back yard. One of these days I have to do something with these parts, can't just let them sit here forever...
Option 3: I've always thought that Jeep factory hardtops look like upside-down bathtubs, so I've always wanted to build a completely custom hardtop with a little more style. If you've read some of my other threads, you've seen the modular design I've come up with for a hardtop system - using a series of common components, custom hardtops could be assembled for everything from Jeep pickups like the Gaucho to standard length CJ/YJ/TJ tops, all the way to LJ and Scrambler tops. The longer tops, like the LJ and Scrambler, could have a normal or an extended-height roof. I've figured out the engineering so the same parts could build a top for a CJ/YJ or for a TJ, dealing with the different methods of windshield top attachment. Rear door would be a swing-up hatch for the CJ series tops, but for the YJ and TJ series tops, the rear door would consist of a "half upper" that attaches to the stock tailgate, similar in concept to how a hard half-upper attaches to a half-door. I've worked out all the design and engineering issues for this project, and done detailed drawings for most of the components, here are just a few concept drawings...
Option 3a: Once the top molds were built, there would be any number of custom projects I could build with these tops. For my own use, I'd like to build a full-length Safari top with the extended-height roof for a 2005/2006 Wrangler Unlimited.
Or, Option 3b, if I decided to build another custom Jeep, I could build a long-wheelbase YJ with a Safari top in either pickup length or the full-length extended roof version, for example...
If I do the Safari top project, I'd start by building a pickup cab first, it would be easiest to do a smaller top first, plus that would give me all of the complicated modules I'd need to build the full-length top as the second phase of the project.
Option 4: Of course there's always the Mahindra Marshall 4-door idea, I would have my friends in India buy me a Marshall, disassemble it and send me the complete body. Over here, I'd build it onto a 2004/2006 Wrangler Unlimited chassis, so it could be a DOT-legal vehicle in this country and have all the benefits of the proven TJ mechanicals. But I think I'll hold off on this idea for some year in the future.
I'll be pondering this decision through the holiday season with the idea that I'd probably start whatever new project I decide on in mid-January. As always, your thoughtful input is welcome.![]()
so I look forward to the next "build".I know what you mean but I'm having trouble envisioning how it would work. Tow dollies are extremely short, and have a very wide wheelbase with an underslung axle that's very close to the ground; cargo trailers need to be longer to be useful and generally higher from the ground than a dolly.
I need a dolly very infrequently, so I'll leave that to U-Haul. Fetching body parts, tubs, frames, etc., is much more common for me to do on a project, maybe 3, 4, 5 trips per project, so a cargo trailer would be the one to build.
I'm curious. Would not a tandem trailer capable of hauling a tub also be capable a vehicle on it? Why would you need a dolly at all if you had that car hauler trailer?
Sorry, just a little confused here... :U![]()
Gotcha...
I guess the confusion still hanging around for me is why build a tandem trailer for four to five hundred pounds?
Jeff,
You never cease to amaze, I'm not going to vote for any of the projects as each of the prevous ones have been a gold mine of good tips and techniques, although they are wasted on me...... I will suggest that if you do decide to finish the Gaucho, and you deire to remain as close to original, wasn't the original a narrow trac? If you want to build it for fun and not necessarily duplicate the original, I'd go with a 4.0/AW4? and a D300 with a scout or narrow trac Wagoneer 44 in the back and the stock CJ WT 30 warmed over up front, or 360/auto trans/D300.
If you decide not to bother with finishing it I would sure love to bring it down here and build it, or rather I would love to have it finished and down here for my DD, but I know that isn't very likely uless my retirement plan works out (come on powerball!!!).
Whichever way you decide to go I'll be looking forward to the build and enjoying every step of the way
I built the Gaucho for WT axles, NT's won't fit around the bed in the back. The bed is only 44 inches wide inside as it is, I didn't want to make it even narrower for the original NT's, so I went with WTs'.
NT Waggy--wider than a WT CJ, it's what I'm running. Ideal CJ width IMHO.
