New World Cabs?
jp magazine article
there was a jp magazine article a while back that they documented a bunch of things with either a TJ hardtop on a YJ or a YJ hardtop onto a TJ.. can't remember, But, if I remember correctly they took the TJ windshield gasket off the top, and reused it onto a YJ windshield frame.
anyone remember that article?
drawings look good jeff....
another engineering/design aesthetic item to decide I guess is whether the back corners would be rounded like the world cab to match a brute cab or modified TJ cab.. or have it taper over the bedrails or have a cutout to account for the bedrails if it was used on standard LJ or TJ that the tub was not cut in half.
My index says: "Updating your soft top", November 2007, it is an article about putting a TJ soft top on a YJ. I'll check it out later today when I get home.
My plan is to make them rounded to match the WC/back of the tub. They can be notched to go over the side rails in the case of a half-cab on an unmodified tub, I believe they'll look fine that way. If not, since it's modular, only the rear corner modules need to be mastered/molded if we want to do angled ones.
BTW, I went back to the Pick n Pull and grabbed that TJ windshield frame, seems like something too good to go to the crusher. Might come in handy for mocking up parts for the Safari top. Besides I can sell the visors and hinges on eBay for more than twice what the whole thing cost me :)
Here's a photo of the top of the TJ frame without the gasket. The only real difference between this and the top of the CJ frame is the angle cut off the upper lip, and a lower ridge at the front of the horizontal part. But it still looks to me like you can make a TJ-style header attachment and use it with all TJ, YJ and CJ windshield frames, as long as you put the TJ gasket on the YJ or CJ frame. I wonder how much the gasket retails for?
attachment.php
A while back in this thread there was some discussion about the high "X" roofline and whether it could look right, especially in the rear view. I remembered I had some photos of similar rooflines from India... The Mahindra body is a few inches wider than the CJ body, though (in the rear the extra width is in the door), so to have the same roofline look in the rear, the height of the roof on a US Jeep would have to be proportionately lower to look the same. But in any case, I think this shows a higher roofline can look ok in the back view...
attachment.php
I don't know if you have seen the Storm 2 but it is a 4dr with a high roof
Not a good backview of a high roof TJ but here it is:
It is interesting that they use two door latches on the rear door
From the side. I don't think the rear door was done that well
I also think the roof is a lttle on the high side but the rear air is cool
More images here:
FWIW, I don't like the proportions on any of those Storms/Mahindras. Always had an issue with them specifically because the lines look all wrong to me, hence my concern about the X version, but obviously it appears I'm in the minority (I'm real used to that though :D)
There's a smal ridge on the side of the Mahindra roof that looks like where the roofline should be.
I've been working on the Safari Cab design a little more in preparation for making scale concept models, and I did a crude edit of an 80's Venezuelan Llanero photo (original is inset) to approximate the proportions of the higher roofline on an LJ. My drawing shows a "stepped" roofline, while the Llanero has a more simple slope in the front third of the roof; I'm considering both shapes for the Safari Cab roof.
Also, in order for the modular parts to work properly for both pickup cabs and wagon cabs, the rear wall needs to be more vertical than the rear wall on say, a World Cab, because the pickup cab rear wall needs to be very near vertical. The Llanera rear wall is pretty close to what I'm thinking, its just a few degrees sloped forward from vertical.
I'm also considering two side windows on the LJ version - a wide window for the passenger seat, and a narrower window for the cargo area.
Comments please.
attachment.php
I like the two windows, the way they fall relative to the passengers and cargo area just looks "right".
I don't like the extra step and height in the rear. It looks too tall to me and the vertical rear wall (which I compltely understand the need for) sort of emphasises it.
Here's my take:
attachment.php
Here's my take:
attachment.php
I've drawn that version too, just haven't posted it :). I'll probably build all three versions for the scale model so we can look at them in 3-d.
Oops, hope I didn't jump the gun! :shrug:
The model versions will be perfect to check these all out. :thumbsup:
On no, of course not... I typically do dozens of concept drawings, but I only post the ones I want comments on, or the ones I really like. In this case, the version you did is one that definitely looks good so I didn't post it - I only posted the high roof ones because they are the ones I'm not sure about.
Yup, that's why I have to do models, I wouldn't go ahead building full scale high roof versions without being convinced by scale models that they will look right. I'll post all variations of the scale models I build and everyone can comment on those.
Here's another roughly edited photo - the top two photos are of a Korean Korando (the tan one), and an unidentified hardtop on a what appears to be a Scrambler. I don't know much about either vehicle in the photo, but the Jeep has a high roof with a near-vertical rear wall. The bottom photo is an edit of the Jeep to roughly the proportions of an LJ, also with windows closer to what I'd do, the original windows on the white Jeep are larger than I would do on the Safari Cab. I wish I had some better photos of the white Jeep to edit, but this is all I've found.
attachment.php
Here's another, even rougher edit of those photos. :) Obviously the front and back photos are at different angles, but the proportions are roughly correct.
attachment.php
Just a thought...
Pay attention to the angles of the windows in the rear. One of my largest issues with most of the Scrambler hard tops I have seen/run is that the windows are cut weird. Personally, I think they look best with straight 90* angles... Or, with angles that match the front doors.
Just a thought...
Completely agree - the size, placement, shape, angle and number of windows is key in defining the right look. And agree that many of the aftermarket tops have goofy windows. My plan is to build the models with no windows to start, and then try various windows using stickers until I find the right ones.
EDIT: Here's an example of lack of window design:
attachment.php
attachment.php
That tan hartop on the red wrangler is hideous:huh::shrug:
Jeff,
What about going the other way. EXTEND the LJ to CJ8 proportions and mount the WC on that?could even mess about with some scrapped ones and get the proportions right.
This thread makes me want to put the Overlander top back on. Must fix the A/C though, 37c is a bit much with no chillers!!!
Jeff,
I think we covered this earlier in the thread, but I did consider that option briefly since I do have all of the materials necessary for that project: I've got plenty of TJ frame rail and also the back half of the LJ tub from the Retro Wrangler project.
I decided against it because then I wouldn't be able to use the factory LJ soft top, and I definitely want to drive it topless in the summer. And no, the Bestop Scrambler full soft top wouldn't be an option for me, I just put on on my Scrambler to prepare it for sale and I learned from that experience just how much better the LJ factory top is, I couldn't settle for a Bestop after becoming accustomed to the fit, watertightness and ease of putting down the factory top.
I'm leaning towards building the fiberglass Safari Cab for the LJ and selling the World Cab but I won't decide if I'm going to proceed on the Safari project until after I finish the scale concept models. I'll start the models later this week.
would agree. the drawings with the smaller "1/4" window in the back has a much more appealing appearance than 2 windows of equal size.
having sold the full length CJ8 hardtops for a while, I will say people do like the side windows on the full length CJ8 hardtop to be able to be opened for ventilation. I think you would probably still accomplish this by having the rear qtr window "popout".
having said that, that gets into the topic of what do you actually use for that window the rear qtr window and the "Fixed" side windows.. Just standard flat cut auto glass for the sides and whether it would have to be "contoured"to match any shape of the top and/or mounting hole. Would have to find an existing OEM manufacturer window of something or having something created for a framed camper type popout type window.
I believe the XJ cherokee 2 doors had somewhat of a simliiar setup but it was an all 1 piece window though. fixed front part and then rear part popped out for ventiliation.
In the case of just making this for yourself would just want to make sure you were able to find enough to build your tops, and possibly know of a replacement window ..... OR if you had them reproduced, (hmmmm) would have to figure out how to have a cost effective window designed and manufactured that would work with the application.
If you made a size poput window for the full tops, maybe could make it so it also works in the rear back face of the tops and/or the rear back face of the halftops.
The option I'm considering for the top for my LJ would be to use the FJ-40 pop-out windows, I posted this photo earlier in the thread but I'll repeat it here. Unfortunately you can't really see the window details because of the frost. I'll try to get some better photos of the pop-out window detail when I get home later this week.
The FJ-40 pop-out windows are the correct size and shape for my Safari Cab design, so they could be used without modification. I believe the glass, hardware and weatherstrip is available aftermarket for these windows, so if these tops were to be produced in volume these could probably be used. UNlike the main side window, which are weatherstripped into the flat side panels, the pop-outs have special recesses in the sheet metal they fit into, so that would have to be reproduced in the fiberglass side panel. Shouldn't be too much of a challenge to reproduce the details of the frame in the fiberglass panel.
The nice thing about the modular construction design also is that we could make multiple side panels for different types of windows, so one possibility would be that I could use the FJ-40 pop-outs on my LJ top, but if the tops were to be manufactured, some other custom or RV window could be used, perhaps with a slider like the Gr8Tops windows.
attachment.php
Another thought I had about using the FJ-40 windows... I've seen some minivans with motorized pop-out windows in the back... before I finalize my plan I'll visit the pick-n-pull to see if those mechanisms could be adapted to the FJ windows to motorized them :)
