Ford Prefect
- Provo
- UT
This one was my favorite for the LJ by far; I have always thought that the LJ top had something missing, and I think you have found it for sure! I think that the lines look really bad on the WC cab version in comparison with this one.
The one possible negative is that thing would be a total beast to try to install/ remove.
Along the idea of the top that can be more WC like (in that you can divide the pieces) do you think that you could use a band of metal. IE a strap over the top in the front and rear welded to rails that run the length of the lid, and then another frame in each side, actually inside the mold of the top? Would that give you the strength that you would need to be able to separate the pieces?
I really like the stake pocket rear window, that is a great idea! I think that, however, you may need some support. I think if you used a hinge more like that of the front doors, then you would find that it would work out nicely... Obviously you will have to have the hinge actually removed from the door (ie on an L bracket) so that you would reduce the binding, but if you have a hinge that simply lifts off with the pocket window that would, I think, work out really easily and still give you rigidity that you would, I think, need. (I just think that over time that extra window would ultimately bend the TJ/YJ door and progressively cause problems closing and sealing.)
Several have mentioned concerns about the strength of the top. Do you think that a load on that roof rack might be enough to crush the top in? How would that Xterra one look without the rack? Personally I love the rack, perhaps you would just have to remember never to actually use it for more than the Christmas tree...
DONAGHY, I think if you are concerned about making it seal up every time, why not consider a disposable weather stripping of some kind. IE like the foam/rubber crap you buy to stick in your front door jam. If you took that off and replaced it every time you rebuilt the top then I think you would find sufficiently seal with ease.
I think if you DID go with the Safari-X (like the name better too) then I would personally simply install a new roll cage system. I should tell you that I am more of the wheeling crawler mindset than I believe many in this thread to be, so I may be in the minority, but to me that roll bar being so low is a real non-issue.
By the way I love the M715 wrangler idea. I could really see that being done by someone on JF.
Last thought... GOODNESS! I thought I was never going to get to the end of this thread, and now that I have it is some what surreal. I do not know where to go, I am just sitting here looking around, some what lost.
At any rate, I love the ideas, and thanks Jeff for pointing me to this thread.
I'm not into JK's. The only ideas and concept drawings I've done for JK's so far are pickup concepts, I haven't done any concepts for the 4-door.
