New World Cabs?
Here's a little more detailed look at what a Safari pickup cab might look like. It's got a World Cab roofline - the same rake and ribs as I did on the Retro, and FJ-40-style corner windows.
attachment.php
Jeff, if you ever build the Safari Wagon LJ top to fit a Scrambler, I want one. Love those corner windows!
It could even use a liftgate instead of being hinged with the tailgate.
A longer pickup cab on a longer Gaucho (Retro-length cab and bed). With a fender modified to have a spare cutout.
attachment.php
Remember the old j-truck stepside Honchos? Maybe I should apologize for this next one, or at least apologize for the groovy 70's graphics... :)
It's basically a Retro Wrangler, with new Honcho-inspired rear fenders, also sporting the Safari Cab. If you look beyond the graphics, these fenders work pretty well with the rest of the Retro design.
attachment.php
If I ever built another Wrangler-based pickup, this might be the one (without the graphics of course!) Might be a fun challenge to build these fenders from scratch in fiberglass.
Enough of the strange concepts for this morning...
Groovy!
I like the groovy graphics. What does that say about me?
That safari top looks awesome on the Gaucho. I like the extra visibility the Fj windows should provide. Every day I take my daughter to swim pactice I come to a diagonal intersection. Luckily shes with me cause its very hard to get a good look with the standard Scrambler 1/2 top.
Yesterday's excursion was to pick up an FJ40 hardtop I got for very cheap; it isn't in very good condition to restore for use on an FJ, but it's just what I need to see if any of the windows or other parts would be useful in the Safari cab design.
I expected the radius of the back corners to be different, but I didn't know how much different until I was able to compare the FJ and CJ parts side by side. The rear radius of the CJ tub is about 3.5"; the FJ radius is about 5.5". That doesn't bode well for using the curved corner windows, it might be hard to find a body line and shape solution for the Safari cab that looks natural given that difference. It's a problem I'll work on.
But here's a REALLY interesting find - the height of the FJ40 windows is exactly the same height as the window openings in the Postal Top. The inner skin of the World Cab van top (a.k.a. Alaskan Postal top) is stamped for a window cutout, and when I put the windows in my top I followed this cutout. News flash: if you're putting windows in an Alaskan Postal top, the rear tilt out windows from an FJ40 are a perfect fit. Maybe someday when I modify my World Cab to fit a Wrangler Unlimited I'll add these windows to it ;) (Don't mind the frost on the FJ windows, the glass is perfect. I left these parts outside last night and it's cold here!)
attachment.php
I also got the rear "ambulance doors" to go with the FJ top. It turns out the FJ's tailgate opening is 5" wider than the CJ's (41" vs 36"), so putting both doors on a CJ for the Safari top wouldn't work, BUT... my plan for the Wrangler TJ/YJ/LJ version of the Safari top is to retain the stock Wrangler swinging tailgate, and build a "half upper" that attaches to the stock tailgate to make a full swinging barn door. It would attach using "stakes" somewhat similar to the way half door uppers attach to half door. (BTW, look at the huge stake at the front of the FJ side panel in the photo above) Well it turns out if the two doors are sectioned and joined together, the top half is exactly the right size to be the Safari half-upper (dashed lines in the photo of the digitally joined doors).
For the CJ version of the Safari top, my design calls for a liftgate - the modified FJ sheet metal would also be perfect for a liftgate.
Or, in both cases, probably the modified FJ sheet metal would serve as a mold master for fiberglass half uppers for both Wrangler's and CJ's.
BTW, the top half of a DJ Postal door would work fine for the half upper for the Safari top also. The modified FJ doors would be a nicer fit because of the cheesy way the DJ Postal "overlaps" the door opening though. I've still got the remains of the DJ door that donated the logo to the Gaucho tailgate, so I can experiment with both.
attachment.php
Finally, did you know the FJ roof panels are made of fiberglass? I didn't until yesterday. What I found interesting here is that these roof panels have a sheet metal drip rail (all rusted off this roof except for a small bit remaining on the back edge, not visible in this photo). Anyway, the way they do the drip rail is exactly the same as I designed for the fiberglass roof on the Safari top (I mentioned that I solved this design problem in a post a while back). I guess it's good to know my design solution for the drip rail has been used before on a production top.
attachment.php
So, summary:
1. The swing out windows are a really nice find for someone putting windows in an Alaskan Postal top. (and would certain be usable in the Safari top design)
2. The rear corner windows will be tough to use on the Safari top because of the radius, but I'll be working on design solutions.
3. The rear ambulance doors will customize into a perfect rear upper door for the Safari cab.
So I was thinking about the FJ40 rear curved windows, and decided to see what the Safari top would look like without them, but using the flip open side windows, and also adding quarter windows in the back. Here's a short version on a TJ, also compared to a stock TJ top.
attachment.php
Jeff, those Safari tops are awesome! Has to be your next endeavor. Makes the stock TJ top look awful.
i agree... stock top looks like a$$ now... BUILD IT!!!
Ah yes, but I've got nothing to put it on right now... can't build it blind, need a test mule vehicle to build it on. C'mon, who wants to trade me a TJ or LJ for the Gaucho, if someone does that I promise I'll build it :)
Love the look of it, but the inner engineer in me is wondering about the structural integrity of those corners with all that glass and relatively little fiberglass if you use the quarter windows. Referring you to the World Cab, there's a major reinforcing "tube" on either side of the rear door. You're going to have a very narrow strip of fiberglass between the opening and that door. I know the WC is metal, but you just don't have much "meat" vertically after the vent windows.
I'm sure the windows will be able to bear some of the weight and you'd know better than me at the toughness of the little strip beside the rear door with "normal" use. Just wanted to throw that out there.
Definitely agree about that engineering problem, have to do something about it for sure. I was thinking metal reinforcement inside the fiberglass, perhaps a 3/4" square tube frame. I've got to research bonding fiberglass to metal, not sure that's always reliable. Perhaps will have to be bonded after the molding with structural adhesive. I'm working on the problem already though.
On something as long as a Scrambler, you'd probably have two side windows instead of one large one. Rear view would be pretty much the same as the TJ view I posted earlier because it would come out of the same mold - except the center "barn door" would be instead be the stock Scrambler tailgate plus a swing-up liftgate, the liftgate would be the same upper half as on the TJ drawing. Would still have quarter windows on the side.
attachment.php
And I saw a silver Nissan Xterra on the way home today, so on this one I raised the back part of the roof and put on an Xterra-type rack...
attachment.php
