Yesterday's excursion was to pick up an FJ40 hardtop I got for very cheap; it isn't in very good condition to restore for use on an FJ, but it's just what I need to see if any of the windows or other parts would be useful in the Safari cab design.
I expected the radius of the back corners to be different, but I didn't know how much different until I was able to compare the FJ and CJ parts side by side. The rear radius of the CJ tub is about 3.5"; the FJ radius is about 5.5". That doesn't bode well for using the curved corner windows, it might be hard to find a body line and shape solution for the Safari cab that looks natural given that difference. It's a problem I'll work on.
But here's a REALLY interesting find - the height of the FJ40 windows is exactly the same height as the window openings in the Postal Top. The inner skin of the World Cab van top (a.k.a. Alaskan Postal top) is stamped for a window cutout, and when I put the windows in my top I followed this cutout. News flash: if you're putting windows in an Alaskan Postal top, the rear tilt out windows from an FJ40 are a perfect fit. Maybe someday when I modify my World Cab to fit a Wrangler Unlimited I'll add these windows to it
(Don't mind the frost on the FJ windows, the glass is perfect. I left these parts outside last night and it's cold here!)
I also got the rear "ambulance doors" to go with the FJ top. It turns out the FJ's tailgate opening is 5" wider than the CJ's (41" vs 36"), so putting both doors on a CJ for the Safari top wouldn't work, BUT... my plan for the Wrangler TJ/YJ/LJ version of the Safari top is to retain the stock Wrangler swinging tailgate, and build a "half upper" that attaches to the stock tailgate to make a full swinging barn door. It would attach using "stakes" somewhat similar to the way half door uppers attach to half door. (BTW, look at the huge stake at the front of the FJ side panel in the photo above) Well it turns out if the two doors are sectioned and joined together, the top half is exactly the right size to be the Safari half-upper (dashed lines in the photo of the digitally joined doors).
For the CJ version of the Safari top, my design calls for a liftgate - the modified FJ sheet metal would also be perfect for a liftgate.
Or, in both cases, probably the modified FJ sheet metal would serve as a mold master for fiberglass half uppers for both Wrangler's and CJ's.
BTW, the top half of a DJ Postal door would work fine for the half upper for the Safari top also. The modified FJ doors would be a nicer fit because of the cheesy way the DJ Postal "overlaps" the door opening though. I've still got the remains of the DJ door that donated the logo to the Gaucho tailgate, so I can experiment with both.
Finally, did you know the FJ roof panels are made of fiberglass? I didn't until yesterday. What I found interesting here is that these roof panels have a sheet metal drip rail (all rusted off this roof except for a small bit remaining on the back edge, not visible in this photo). Anyway, the way they do the drip rail is exactly the same as I designed for the fiberglass roof on the Safari top (I mentioned that I solved this design problem in a post a while back). I guess it's good to know my design solution for the drip rail has been used before on a production top.
So, summary:
1. The swing out windows are a really nice find for someone putting windows in an Alaskan Postal top. (and would certain be usable in the Safari top design)
2. The rear corner windows will be tough to use on the Safari top because of the radius, but I'll be working on design solutions.
3. The rear ambulance doors will customize into a perfect rear upper door for the Safari cab.
