The option I'm considering for the top for my LJ would be to use the FJ-40 pop-out windows, I posted this photo earlier in the thread but I'll repeat it here. Unfortunately you can't really see the window details because of the frost. I'll try to get some better photos of the pop-out window detail when I get home later this week.
The FJ-40 pop-out windows are the correct size and shape for my Safari Cab design, so they could be used without modification. I believe the glass, hardware and weatherstrip is available aftermarket for these windows, so if these tops were to be produced in volume these could probably be used. UNlike the main side window, which are weatherstripped into the flat side panels, the pop-outs have special recesses in the sheet metal they fit into, so that would have to be reproduced in the fiberglass side panel. Shouldn't be too much of a challenge to reproduce the details of the frame in the fiberglass panel.
The nice thing about the modular construction design also is that we could make multiple side panels for different types of windows, so one possibility would be that I could use the FJ-40 pop-outs on my LJ top, but if the tops were to be manufactured, some other custom or RV window could be used, perhaps with a slider like the Gr8Tops windows.
Another thought I had about using the FJ-40 windows... I've seen some minivans with motorized pop-out windows in the back... before I finalize my plan I'll visit the pick-n-pull to see if those mechanisms could be adapted to the FJ windows to motorized them
