W.R.Buchanan
- Ojai
- CA
I am taking this topic from the Fab Section and expanding on a post I put there with respect to mounting your Hi-lift Jack.
Guys: I see this all of the time in my home town of Ventura CA. A guy buys a Jeep and then spends a bunch of money "outfitting" it. And then he proceeds to drive back and forth to work everyday with said "outfit" firmly attached to the vehicle.
The likelyhood of using any of the external equipment on your Jeep in town is just about zero! However you pay for dragging it around everytime you drive the Jeep. You pay for it in fuel mileage decreases and wear and tear of the extra weight on the vehicle, and in deterioration from exosure.
I have one guy down the street from me who has a 04TJ. It has a square tube rear bumper he had built which easily weighs 200 lbs. Add to that the spare 35" tire 100lbs, the over tire rack with dual gascans 100lb empty, 200lb full, and the full length Con-ferr Roof rack and mount structure, with Hi-lift mounted and you have just added another 500lbs. He also has a Hanson front bumper with Warn 8274 winch attached for a total of about 1300lbs.
He drives this Jeep 30 miles back and forth to Port Hueneme naval base everyday, and lets the Jeep sit in the sun within 1/4 mile of the Pacific Ocean. He doesn't understand why his Jeep averages 11-12 MPG!
Also after 3-4 years of having the unused equipment exposed daily to the elements, all of it is rusty and going to hell fast.
The only possible reason that this equipment would be used is if the base was attacked and he had to Bug Out from work. Then he'd be well equipped, as I'm pretty sure he has all of his camping gear in a box in the rear seat of the Jeep too..
Point of all this rant is to get people to see that convincing the general public that you are some big 4WD Expeditionier outdoors type won't get you any girls.
All it does is cost you money and use up your equipment prematurely.
I have, since the beginning, built my Jeeps so that all of the equipment could be quickly removed and stowed in the garage to keep it nice and out of the weather. I still have everything I originally purchased 14-18 years ago and all of it looks essentially new. And why not? It has hardly been used.
That's not to say it hasn't been along for the 100 or so trips, it just been taken care of. And the primary way I take care of it is to put it in the garage when it is not being used. I can have it all attached to the Jeep in 20 minutes and be gone.
Plus that I have never had anything stolen off my Jeeps, and I live in a place where it damn sure is a distinct possibility.
So, strip the Jeep when you get back from a trip, keep the stuff in the garage, and it wouldn't hurt to put the Jeep in the garage too.
Just some thoughts for you guys to ponder.
Randy
Randy
It will be reincarnated as sometihng else after the new one is done. Notice it is in the garage? It is 14 years since it was built. Top is still good too!
