OK, I've been digging around trying to get my liquid check valve (LCV) and roll-over valve (ROV) installed, and here's what I can come up with:
There are basically two ways for gasoline to get IN to the canister: the carb bowl vent and the roll-over valve/liquid check valve via the tank. They traditionally only allow vapor in, but Houston, you might have a problem.
I'd check first to see if you have a MC with bowl venting. If so, you could be pulling excess liquid gasoline off of your carb. Don't ask me why, or how, I'm new at this. If you have no bowl vent (I think this is how a lot of MC's came), then check your rear liquid check and roll-over valves, driver's side rear, just behind the tail light. Mine looked like this, and despite how bad they look, at least I wasn't drawing gasoline into the canister:
If they are intact and non-functional, you could be pulling vapors from the tank, which condense in the LCV and pass through the ROV to the canister. It would take a lot of build-up, and a lot of rear heat +/- pressure to do this.
OK, that's how gasoline can get INTO the canister. The alternative (or secondary) problem is that for some reason, you are not drawing the vapors that go into the canister back out like you're supposed to! I don't think this could lead to as much liquid gas build-up as you mention, but what do I know, I'm new at this. There is a single exit port coming out of the canister, and it goes to the manifold-vacuum port at the rear of the MC, the same one which draws from the PCV valve. There is a
signal from the CTO to purge the canister, so if either the
signal is not functioning (it requires ported vacuum from the side-port of the carb, the same one which feeds the vacuum advance system), or if the
purge line is blocked, you won't get gasoline vapors pulled from the canister.
Make sense? You're probably out-of-country by now and it won't matter, but that's my expert opinion. You can pay me when you return
-N
