It is unbelievable how much work your getting done in such a short time Mike...
I pray for your strength as you love on your father... that dashwork looks incredible whats the "secret sauce" you use on the dash pad?
So earlier in the thread I had mentioned I had no idea the switch in the glove box was for the 4 way flashers(was just resting in it). Well after that bit of reasearch I "thought" the switch was mounted to the metal portion of the glove box lip. Well I was digging thru a few boxes of misc stuff my dad had gotten when he bought the car and I found this.
From my understanding and reading 66' was the one year where the switch is hardwired to the harness and replacements were a blade style switch. Well I found this bezel with a blade style switch on it so there is a spare. The other thing I finally figured out is the fact the switch bezel actually mounts to the carboard glovebox insert--odd. In any case when I get the replacement insert I can install it correctly now.
So the last couple nights have been slow going--mainly because I am taking my time to make sure its as good as I can make it--plus this small stuff just takes time.
So This was harder than I thought--trying to replace the E-brake handle. The handle it held on by a pin. Well after some work I found if I pushed the pin all the way in--and then drilled a small portion of the end off I could remove the handle. Once it was off there was a shole in the ebrake rod that let me force the pin back out. In any case thats DONE!
This also took some time mainly to make sure and not scratch the newly painted dash. I also dissassembled the whole thing and polished it up. There was a spare on in the box of stuff so I swapped parts as need be and made a VERY nice assembly out of it. I also hooked both heat and temp cables up. Once we get the new defrost parts I can hook that up. But it turned out pretty nice.
So tonight was also slow going. I spend a bunch of time painting the last dash parts. Don has been getting big parts put on. Look a hood..
Don had put the trunk lid on and we found the one my dad had is bent funny. So we went back to the origonal one and Don has to finsih stripping it--and that will go on.
I made brackets and got the new fuse block secured and loaded with fuses--so that is DONE!!!
So I have been trying to get the car ready to take it to the body guy on monday. Unfortunately the oriognal plan I would not be able to drive it out. Well as it ends up he is leaving tues for a week and the car would sit. So We are going to wait till he gets back which will give me more time to finish up more of these small items..
Ok the last few days have been unproductive due to other things I have been doing. But I did end up spending a day cleaning the shop and going thru everything thats been removed from the car and made another list of things we need to replace. But I did manage to get back into it today and start back into making progress.
I ended up tearing the pedal assembly loose to grease it up and add a shim in it to tighten it up. Down the road I will have to remove the whole thing and rebuild it with all new sleeves and ends. But I was able to get it working a ton better and not making any nasty squeak noise like it was. Also I added some paint to it and I found a better set of pads in one of the boxes of stuff so I swapped them out.
Ok so I was digging thru the boxes of stuff and I found the cig lighter for the car. Of course I polished it up and threw it in and also threw the ignition lock cylinder back in.
I also got the newly painted ash tray back in. Still waiting for bump stops for it so I made sure not to push it all the way in. Man does the dust build up quickly--granted Don doing more sanding here and there doesn't help any,lol.
Now here is where I am still confused/trying to figure things out. My dad got a used acelerator link and first glance it looked like it might work(and made how its setup make more sense) and he got the pedal, linkage from the link to the carb and return spring. Well I tossed it into place to see and the carb side is too short.
The longer end is the end that goes thru the firewall and what the pedal bolts too. The short end is the carb side but its needs to be about 6" longer from what I can tell. So at this point I am not sure of what it what really.
I had asked my dad if his under dash lamps ever worked--he looked at me and said "there was underdash lamps" ha ha ha. Ya I guess they never worked,lol.
Well I cleaned and painted the mounts and new bulbs and got them installed on both passenger/driver side.
One thing I have been trying to get to was the rear passenger windows. The driver side needed help to roll it up/down and the passenger, well it fell down and won't go back up. Wellsince my list of need to do's before paint is getting small and my needed parts is smaller I figured I would dive into them.
Started by tearing apart the drivers side. It actually was easier than I thought. Started by removing the one remocable guide rail, the regulator and then you remove the main track assembly, slide the window out then the track assembly.
I cleaned the window, polished the chrome to remove the black overspray from when the interior was painted. I sanded down all the guides and emeryclothed the plastic parts that ride in the guides lightly.
All ready to go back together.
So I lubed all the tracks and reinstalled everything back into the drivers side. Now the widow moves like silk and works pretty good. You can tell there is a little wear on the regulator and other components but in all its really good.
I then tore down the passenger side. The main roller had popped off the guide on the bottom of the window. That was probably due to too much force to overcome the rusted tracks. I should be able to fix this side up too.. Will know more later tonight.
So like I had mentioned earlier I was going to make the accelerator rod we had work. Well it took allot of work and allot of in/out to get it right. I am very confident its going to work perfect and it seems to.
I am not 100% sure on the pedal location as it sits. I won't know till the interior is in to be 100% certain on it--but it looks pretty close.
In order to make the passenger side mount I flipped it(once the rod was cut I was able to remove it) and notched it for brake line clearance.
I lengthened and bent the rod accordingly and was able to get the geometry right on the money. I still need to make a tab off the bottom of the rod for the return spring to sit. But clearance to the intake manifold and the angles on the pivat points are right on.
Due to the carb being different than the stock one I am pretty certain the linkage mounts are too. So I had to slightly modify the carb(removed one ball pivat) and made a new mount for the linkage to mount to. It turned out pretty good and when the throttle linkage goes from idle to wot its perfect.
So I pulled it last night and added a tab for the return spring and painted it all up. I will have that installed tonight.
So I got the painted parts put in. My dad is looking for a new boot where the rod goes thru the firewall--it has a small hole in it. if he can find one I will fix it.
It seems to be working excelent and very smooth. But thats by hand and hard to tell since we are trained to use out foot for the pedals and that will tell the story.
Well I was able to get all 7 broken 1/4" bolts done. My first one I tried an easyout and it was rock solid. You could tell they were throughly rusted in place.
The key was to start with a small drill bit to get you center and work your way up. If you are nads on with your center hole your golden. I then worked my way up to a 3/16" drill bit and I was able to get the bolt to unscrew inwards. If your nads on you will have a winding of threads with zero damage to the threads on the car.
I only had 2 holes that barely nicked the edges of the threads and left some threads that were easily removed with my tap.
So my list is growing small. I decided to clean the area behind the rear seat. The stock divider between the trunk and seat was glue to the body and left crap stuck to it.
I also cleaned both sides of the car where the steel panels go that are next to the rear seats. There was some sticky goo which I assume is to help with the panels to stay in place. In any case thats done.
