am I screwed?
Bushmaster6
the Springs
CO
among all the stupid things I've done in my "career" as a Jeep owner an wannabe handyman, this has to be near the top of the list: :banghead:
doing a valve cover+gasket change to get rid of the leaking plastic stocker..
after I got the old cover/gasket off and finished cleaning up the old RTV, I decided to "test fit" one of the new allen head bolts in the existing threaded holes (pass side), and managed to drop the bolt into the head, and it is now fallen down those open gaps between the pushrods (I assume it's a channel for oil to flow down).. I'm talking about the big gaps between the push rods..
shined a flashlight around at all angles and cannot see the missing bolt..
will it fall down into the oil pan, or is it going to get jammed into some moving parts?
either way, do you think one of those magnets on a rod or a plumber's claw might get to it?
I would definetely try fishing around with a small telescopic magnet. Other than that, I don't know the architecture of the 6 cyl that well, although better to be safe than sorry...
Lost bolt
Are the bolts stainless? The allen heads I have on the valve cover of an engine I bought are. If so the magnet will not help. Maybe you could get lucky and try a smaller hose on a strong wet vac if it is lodged or hanging there. With an allen head it may fit through the hole in the pan drain if that is where it ended up. Try fishing out with a wire with a hook bent on the end.
If some one does not know whether it would end up in the pan I have a 258 I could pull the head and pan off of to see where it would have gone. Between what cylinders did it fall down?
I hate it when stuff like that happens! Hopefully it did fall through to the pan and you can fish it out. Good idea about rigging up a small hose to a shop vac and trying that, too.
Good luck and let us know how it goes.
ran down to Sears this morning and bought a telescoping magnet with the smallest head I could find (and it was on sale).. ran the magnet down the first hole and heard a distintive metal "snap" sound when I hit the bottom of the pushrod.. and voila', the bolt came out attached..
VICTORY.
Congrats! I'm sure that was a great feeling.:woot:
Did you keep the magnet clean enough to return? Might as well try to make it out of this one even-steven.
:woot:
KEEP THAT MAGNET!
Anyone working on any vehicle should have one of these for exactly this reason and many others. I'd never be without one in my garage/shop. You'll find all kinds of ways to use it, not just to retreive things. It's great for getting hard-to-reach nuts started on bolts or to fish bolts into bad spots, etc.
Other thing that's come in handy is a good magnet on a string.
I'd run right out and buy a lottery ticket after that bit of good luck!!! Very nice to hear you lucky dog.
I felt for sure you would have to take off the head! Congrats! That sure saved you a few Saturdays.
I was thinking the same thing, and HI to Daine... nice to see you here to bro!:wave:
I buy one Powerball ticket a week.. a tax on people that can't do math.
my Walmart gives .03 off a gallon to military, so when I fill up the cruiser, that's about 70 cents to me.. nearly enough to justify throwing a dollar at the lottery, so I do..
I haven't hit a SINGLE NUMBER yet.. much less the 6/7 you need to pull in the big winner..
thanks for all the feedback guys.. it's still an interesting question to me, where something might fall/wedge when I falls down one of those holes..
I was curious too:shrug:......I took the head off that engine to see where it would have gone. There is a large oil galley that runs the length of the block where there is only the tops of the lifters and 4 small holes along the length for the oil to return to the pan. The holes were about a 1/4 to 5/16 and a little larger one at the rear of about 3/8. No rotating parts.
If you had not found that smaller magnet, you should have been able to remove a rocker and push rod to get something larger in there. Was going to let you know, but you had already gotten it out:thumbsup:
I'll get some pictures this evening or tomorrow morning.
Picture of block
Here is a picture of where the bolt went. It is hard to tell from the picture, but it is 3 1/2 inches deep from the top of the block and runs the length of the block. The 2 largest holes are shown center and behind the 5th piston.
attachment.php
cool...
believe it or not I dropped a bolt in the hole AGAIN today, but was able to retrieve (again) via the telescoping magnet.. I figure that makes that three dollars "well spent" on that tool
