Bushmaster6
- the Springs
- CO
among all the stupid things I've done in my "career" as a Jeep owner an wannabe handyman, this has to be near the top of the list:
doing a valve cover+gasket change to get rid of the leaking plastic stocker..
after I got the old cover/gasket off and finished cleaning up the old RTV, I decided to "test fit" one of the new allen head bolts in the existing threaded holes (pass side), and managed to drop the bolt into the head, and it is now fallen down those open gaps between the pushrods (I assume it's a channel for oil to flow down).. I'm talking about the big gaps between the push rods..
shined a flashlight around at all angles and cannot see the missing bolt..
will it fall down into the oil pan, or is it going to get jammed into some moving parts?
either way, do you think one of those magnets on a rod or a plumber's claw might get to it?
......I took the head off that engine to see where it would have gone. There is a large oil galley that runs the length of the block where there is only the tops of the lifters and 4 small holes along the length for the oil to return to the pan. The holes were about a 1/4 to 5/16 and a little larger one at the rear of about 3/8. No rotating parts.
