- Dexter
- MI
wheel spacers
With the tires finally supposed to be in today, I did the wheel spacers.
Pulled the tires and cleaned up the face of the rotor from the surface rust that was all over them, this was mentioned in the instructions that came with the spacers. You can also see the factory disc retention clip on the lower right lug, this is for the discs to stay on during assembly, I pulled all of them out to ensure they didn't cause the spacer to sit crooked:
Put a thin coat of anti-seize to keep it at bay, careful to keep it off the wheel studs:
Installed the spacers, apparently I failed miserably and forgot to take a shot of the spacer installed before the tire went on. I'll get one when I check the torque on the studs next week or so.
The instructions on the spacers said to torque the lugnuts on the spacers to 95 ft-lb, so I used a torque wrench and stepped up from snug to 50, 75 and 95 ft-lb in the standard star pattern.
Here's where it started:
Here's a shot with the rear one on, front at stock (stock tires):
Here's both on:
Here's both on:
Forgot a picture of that, you'll have to trust me on it... Goes to show how immense the cargo area is on these when the rear seat is out!
